MAIL FROM: <sender@example.com>
250 2.1.0 OK
RCPT TO: <mailbox@example.com>
450 4.1.8 <sender@example.com>: Sender address rejected: Domain not found- /etc/sysconfig/network-scripts/ifcfg-eth0 was a bit broken - note the missing double-quote:
But fixing that didn't help, and at least eth0 comes up now.Code: Select all
... ONBOOT="yes" IPADDR="192.168.1.41 PREFIX="24" #IPADDR="192.168.1.41" #PREFIX="24"" - Default name resolution doesn't work:
$ nslookup gmail.com ;; Got SERVFAIL reply from 127.0.0.1, trying next server ;; connection timed out; no servers could be reached
Updating /etc/resolv.conf so that it has the correct nameservers instead of localhost doesn't fix it either, so there could be something else at play. Right now I've had to disable EFA to get mail flowing - which isn't ideal!
Note that I did find the other similar topics but I don't think they match:
- I already have in mailscanner.conf
define('QUARANTINE_USE_SENDMAIL', false); - The other post is pretty vague but seems to indicate a similar "fix"
