Hello Community,
Does anyone have the same issue as I am having on the latest eFa 4.0.2? I cannot seem to edit any MailScanner Rulesets. Even after giving chmod 777 permissions to the ruleset files didnt help. Pls see attachments. Any help would be greatly appreciated. Thx in advance!
Cannot Edit MailScanner Rulesets
- msre_ruleset2.png (18.44 KiB) Viewed 10253 times
- msre_ruleset.png (14.53 KiB) Viewed 10253 times
Re: Cannot Edit MailScanner Rulesets
Hello Community,
I did find this viewtopic.php?t=1973 but according to the post this issue was supposed to have been fixed already and I am using the default en webgui of efa 4.0.2.
Checked the /var/log/php-fpm/www-error.log and found some errors when executing php scripts from the MSRE rule edit page. Is there a solution to this?
- error.png (16.15 KiB) Viewed 10200 times
Good 'ole permissions. Taking a look...
Thx for making it an issue to be fixed on github. Guess I will use cli to make all the rules for the time being.
sergiupapuc
I have the same error with actual version! ...automatic update are on...
Can you give us a little more detail please?
sergiupapuc
...exactly like in the start of this post, but on uptodate sistem!
- msre_ruleset.png (14.53 KiB) Viewed 9251 times
