Any NetworkManager, with default configuration, in efa will pick up these DHCP settings just fine.
After the upgrade to eFa-4.0.2-13.eFa.el7.x86_64.rpm I did reboot efa. After the reboot I noticed an issue with Unbound.
As I do not reboot to often I'm not sure the update was responsible.
A quick search found that in /etc/resolv.conf the nameserver (nameserver 127.0.0.1) was missing.
I restored the standard behaviour for NetworkManager by commenting the dns=none line
/etc/NetworkManager/NetworkManager.conf
[main]
#dns=none
When N is selected, do not set dns=none in NetworkManager.conf
