Customizing Spam Assassin
gtao725
Post by gtao725 »
Hello Community,
I am new to eFa and I have just set up my own eFa appliance v4.0.2. Could anyone pls tell me which config to edit for customizing Spam Assassin scores? Should it be spamassassin.conf under /etc/MailScanner/ or local.cf under /etc/mail/spamassassin/ ? I am super confused. Thx in advance!
Cheers!
Re: Customizing Spam Assassin
If you search the forums, you'll find the answer.
For customizing the spamassassin scores for your installation, you just edit the /etc/mail/spamassassin/local.cf.
Again, search the forums and you should find examples.
If you can't, then do a google search using the following parameter: "site:forum.efa-project.org local.cf"
gtao725
Post by gtao725 »
Ok thx a lot, much appreciated!
