DCC Plugin score
mattch
DCC Plugin score
Post by mattch »
Hello everyone! :think: :doh:
does anyone know if it's possible to change the default score on DCC_CHECK?
i found some examples for custom rule but then results in two "DCC_CHECKS" in rule descriptions.
So where does the default one hide, or how to change or remove default dcc_check rule?
custom example cf:
ifplugin Mail::SpamAssassin::Plugin::DCC
full     DCC_CHECK      eval:check_dcc()
describe DCC_CHECK     Listed in DCC (http://rhyolite.com/anti-spam/dcc/) -- custom rule
score    DCC_CHECK      2.5 # please adjust the score value
endif
smyers119
Re: DCC Plugin score
Post by smyers119 »
did you try adding
score DCC_CHECK 3
In local.cf
more specifically, anytime you want to override any of the spamassassin scores, you can edit the /etc/mail/spamassassin/local.cf and add in your value
e.g. I copied the BAYES scores from one of the spamassassin cf files and changed the values to something that worked better for me:
# scoring too low.  Increase
score     BAYES_99              4.0  4.0  4.0  4.0
score     BAYES_999             2.0  2.0  2.0  2.0
score     BAYES_00             -6.0 -6.0 -6.0 -6.0
You can verify the updated scoring by running the following command
spamassassin -D -t < $MAILFILE
where $MAILFILE is a stored message file somewhere under your /var/spool/MailScanner/quarantine/<DATE>/spam directory
mattch
Post by mattch »
Thank you that is very clear and precise. i will be customing some more scores now.
adding dcc_check in local.cf did the trick. thanks guys you rock!
