reach https://mirrors.efa-project.orgproblems with
keysteal
Post by keysteal » 23 Mar 2020 11:47
I'm trying to install a new Efa 4 instance, but i've a problem reaching https://mirrors.efa-project.org:
2020.03.23-12:43:00 - ERROR: No network connectivity
2020.03.23-12:43:00 - ERROR: unable to reach https://mirrors.efa-project.org
traceroute to mirrors.efa-project.org (116.203.92.158), 30 hops max, 60 byte packets
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 62-101-124-125.fastres.net (62.101.124.125) 18.058 ms 62-101-124-129.fastres.net (62.101.124.129) 9.330 ms 8.306 ms
7 62-101-124-13.fastres.net (62.101.124.13) 14.559 ms 10.882 ms 9.795 ms
8 decix-gw.hetzner.de (80.81.192.164) 31.273 ms 31.178 ms 32.293 ms
9 core12.nbg1.hetzner.com (213.239.252.26) 42.535 ms core11.nbg1.hetzner.com (213.239.252.22) 39.202 ms core12.nbg1.hetzner.com (213.239.252.26) 37.248 ms
10 spine2.cloud1.nbg1.hetzner.com (85.10.250.214) 38.544 ms 57.532 ms 213-239-208-222.clients.your-server.de (213.239.208.222) 37.516 ms
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Re: reach https://mirrors.efa-project.orgproblems with
Post by henk » 23 Mar 2020 12:18
darky83
Site Admin
Post by darky83 » 23 Mar 2020 12:23
We have monitoring on it from around the world and all say it is active so, must be something local/ISP related.
Try again later, and if it still doesn't work you might try to change the scripts and replace it with dl.efa-project.org
Version eFa 4.0.1 now available!
keysteal
Post by keysteal » 23 Mar 2020 14:22
Thx I will try..
keysteal
Post by keysteal » 23 Mar 2020 14:44
it doesn't work neither with dl.efa-project.org
