Mails not being delivered after "Release"
alexanderbrix
Post by alexanderbrix »
Hi guys,
I have a new problem.
I received some mails today from a sender I know - but it keeps being listed as Spam (light red).
When I click on the message and choose "Release" the mail gets marked as "Released" but I don't get it.
What have I done wrong or misconfigured?
Thank you very much für any replies.
Alex
2020-03-17 11_01_05-RDP-Manager.png (28.53 KiB) Viewed 10924 times
alexanderbrix
Re: Mails not being delivered after "Release"
Update:
I just changed the
define('QUARANTINE_USE_SENDMAIL', true);
in
back to 'false'. Now the mails will be delivered again but as an attachment.
If it is set tu 'true' there is no mail being delivered out of the quarantine...
After you release a message, is there anything that shows up in your log files that could help us figure out what is happening?
alexanderbrix
I just checked the logs and I could find the following:
Mar 20 08:17:47 mail postfix/smtp[58868]: 48kFV30P2wzC9J9: to=<<myname>@<ourdomain>.de>, relay=192.168.x.x[192.168.x.x]:25, delay=0.47, delays=0.44/0.03/0/0, dsn=5.6.7, status=bounced (SMTPUTF8 is required, but was not offered by host 192.168.x.x[192.168.x.x])
Mar 20 08:17:47 mail postfix/cleanup[57995]: 48kFV33gdTz4k18: message-id=<48kFV33gdTz4k18@<maildomain>>
So I checked Google and ran the both commands:
sudo postconf smtputf8_enable=no
sudo postfix reload
It's working again :-)
Had there been any changes in the last update regarding this?
doggy101
Post by doggy101 »
I have a similar isue,
postfix/smtpd[5466]: NOQUEUE: reject: RCPT from localhost.xxxx.loc[127.0.0.1]: 450 4.1.8 <no-reply@EFAmailscanner4.xxxxxxx>: Sender address rejected: Domain not found; from=<no-reply@EFAmailscanner4.xxxxxxxx> to=<emailadress> proto=ESMTP helo=<localhost>
Mar 20 11:39:49 EFAmailscanner postfix/smtpd[5466]: disconnect from localhost.xxxx.loc[127.0.0.1] ehlo=1 mail=1 rcpt=0/1 rset=1 quit=1 commands=4/5
seems that the local server is not allowed to sent out mail.
MauriceW
Post by MauriceW »
@doggy101 Your problem can be fixed by this: viewtopic.php?f=19&t=4178
doggy101
Post by doggy101 »
thanks, will have a look there
