E-mail keeps repeating
arned
Post by arned »
Hello again!
A new problem has occurred,
We have set up our mailserver but whenever I try to send a test mail to an email adress in the domain with the command:
mail -vs "Test DKIM" myusername@mycompany.be < /dev/null
The email doesn't get delivered but instead it keeps resending every few seconds while the file keeps getting bigger.
We could stop this loop by shutting the VM down and waiting a few minutes.
info button -->
Any help or steps in the right direction are much appreciated! :D
Kind regards, 2 students
Re: E-mail keeps repeating
For some reason your eFa thinks of itself as the destination instead of your mail server and is delivering back to itself. Make sure you have defined your mail server correctly.
arned
Post by arned »
Hey Shawn
Thank you for the quick reply!
Do you know in which configuration file I need to look at ?
I looked in Mail settings --> transport settings but everything looked fine.
Thanks in advance!
