Web GUI no messags listing
samrein
Post by samrein »
Hello @all,
since 19.02 i cannot see my messages in the webgui. The postfix runs.
I have updatet to EFA-3.0.2.6.
how can I check why?
I hope anyone can help me.
Regards
Stefan
Re: Web GUI no messags listing
You have 2 options, where option 1 is by far, the best option
1. Update to efa4
2. Enter the next search string in Google, and pick the first [Solved] item on the list.
site:forum.efa-project.org GEOIP
As a last resort you can use this viewtopic.php?t=3311
samrein
Post by samrein »
Hello Henk,
I have seen this solution, but i did not think this is my solution, i will check it.
I'm sure it is.
To speed up migrations to efa4, I could delete the uploaded GEOIP file. ;)
samrein
Post by samrein »
I will definitely do the update soon...
I have updatet the geoip, but i doesnt can see new messages in the webgui.
samrein wrote: 27 Feb 2020 20:49 I have updatet the geoip, but i doesnt can see new messages in the webgui.
Can you describe, step by step, how you updated the GeoIp file?
An old post with isues and solutions for updating from 3.0.2.5 to efa3 EFA-3.0.2.6 viewtopic.php?t=3676
samrein
Post by samrein »
Hi Henk,
I updated the geoip as described in the amount
wget -O geoip.tar.gz download/file.php?id=418
tar -xvzf geoip.tar.gz
cp * /var/www/html/mailscanner/temp/
reboot
I think the geoip is not the problem. They GUI works, only new messages are no longer displayed.
Today i will testing backup machine.
Thank you for your time and support, this is not a matter of course
Hi samrein
To be sure there is a GeoIp file in
If not, extract the geoip.tar.gz without a folder structure
tar xfz /tmp/geoip.tar.gz --strip-components=3 -C /tmp
cp GeoIP* /var/www/html/mailscanner/temp
samrein
Post by samrein »
Thank you... but it does not work...
I have restore a backup from the virtual maschine. That works for the moment.
I will migrate to efa4 the next time.
Thank you for your patience and support.
Regards
Stefan
