EFA 4 & Licensing question
bas60
Post by bas60 »
I'm still using EFA 3 and looking at EFA 4
Currently I have 6 domains - 4 of which are ours - single appliance
I read through the License terms - but not sure if I need to purchase any licensing
I'm not sure I understand the information - I think it relates to distribution
I'm providing a filtering service 2 others & make a small charge for "Support" - 6 users + 15 users
As the numbers are small its probably a overkill for an EFA4 appliance
Do I need a license for any component?
Re: EFA 4 & Licensing question
No, it's all open source.
However, if you're benefiting from the software, you may wish to consider a donation to the EFA or MailWatch developers.
@shawniverson, do you have any thoughts on that?
Just bear in mind the restrictions of using DCC. https://www.dcc-servers.net/dcc/
