Blacklist not showing in mailwatch?
Mr. Happy
Post by Mr. Happy » 13 Feb 2020 09:48
When I put a specific emailaddress (i.e. happy+blacklist@mydomain.org) on the blacklist in efa which is in postfix forwarded to happy@mydomain.org (by using recipient_canonical_maps = regexp:/etc/postfix/recipient_canonical in postfix - which removes the + and everything behind it till the @) it gets blocked (as aspected and supposed to), but does not show up in the mailwatch-page as blacklisted...
If I recall correctly mailwatch did use to show blacklisted emails...
Is it possible to get it shown there (again)?
Re: Blacklist not showing in mailwatch?
Post by henk » 13 Feb 2020 10:33
If you add a blacklist via the Gui, it shows up on the mailwatch-page as blacklisted?
check the Spam settings in
// Do you want the whitelist/blacklist functionality enabled?
// You'll need to configure MailScanner to use it accordingly.
define('LISTS', true);
// Hide High Spam and high mcp from regular users.
// Prevent regular users from seeing high spam and high mcp.
define('HIDE_HIGH_SPAM', false);
Mr. Happy
Post by Mr. Happy » 13 Feb 2020 11:09
The page to display all white- and blacklisted is available (and blacklisted emailaddresses appear there) and the settings are like you showed them.
The blocked emails don't show on the status page (and are also not available in mysql)...
Post by henk » 13 Feb 2020 11:54
The blacklisted items do show fine with me
Can you check your Mailscanner.conf for spam actions?
I use the conf.d directory
/etc/MailScanner/conf.d/01_MailScanner.conf
# Spam Blacklist:
# Make this point to a ruleset, and anything in that ruleset whose value
# is "yes" will *always* be marked as spam.
# This value can be over-ridden by the "Is Definitely Not Spam" setting.
Is Definitely Spam = &SQLBlacklist
Spam Actions = store header "X-Spam-Status:Yes" custom(spam)
High Scoring Spam Actions = store
Mr. Happy
Post by Mr. Happy » 13 Feb 2020 16:33
I have the same settings... :?
I found this line in the maillog
postfix/cleanup[16101]: 48J9cQ6wWTz7D83: milter-reject: END-OF-MESSAGE from mail-m6eur05olkn2043.outbound.protection.outlook.com[40.92.91.43]: 5.7.1 Message Blacklisted;
Could it be because of milter?
Weird... I removed an emailaddress from the blacklist and after that it gets displayed on the status-page and in the logging I get
MailScanner[15675]: Message 48JQN73W4Wz7DGT from 40.92.90.47 (test@hotmail.com) to <mydomain> is spam (blacklisted)
but the emailaddress is no longer in the database as blacklisted...
Solved it... I think... For like forever I had 'default' at 'from' at the blacklist, but it was supposed to be 'defaultS'....
Changed it and it works as it's supposed to :D
