ClamAV not updating after eFa 4.0.2
Good day!
After my system updated automatically to eFa 4.0.2, my clamav database does not update anymore.
My database version right now is:
Version: ClamAV 0.101.5
Virus Identities: 25720
Database Timestamp: Mon Feb 10 13:53:41 2020
Please help!
Please help!
Re: ClamAV not updating after eFa 4.0.2
What happens if you try to manually update?
sudo freshclam
I am seeing the same here.
Repos updated:
[admin@efa ~]$ sudo yum -y update
Loaded plugins: fastestmirror
* base: mirror.nsc.liu.se
* eFa4: dl5.efa-project.org
* epel: mirror.nsc.liu.se
* extras: mirror.nsc.liu.se
* updates: mirror.nsc.liu.se
No packages marked for update
[admin@efa ~]$ sudo freshclam
ClamAV update process started at Wed Feb 12 10:16:32 2020
WARNING: Local version: 0.101.5 Recommended version: 0.102.2
DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav
main.cvd is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr)
daily.cld is up to date (version: 25721, sigs: 2183330, f-level: 63, builder: raynman)
bytecode.cvd is up to date (version: 331, sigs: 94, f-level: 63, builder: anvilleg)
Tried to manually update clamav:
[admin@efa ~]$ sudo yum upgrade clamav
Any tips?
Repos updated:
Any tips?
That is normal, the EPEL folks haven't updated the clam package yet, and that is not the same issue.
Thanks, will have some patience then
Ok,
so oddly enough the problem has gone away just like it came... I hate when that happens...
The output of sudo freshclam was nothing... the process seems to hang for some reason, I could not terminate even with kill... so I rebooted, then tried again - same result, so I rebooted again and then... poof... it's started to update
Two days later the updates are coming without a hitch.
So I will continue to monitor and report if anything brakes down again...
The situation just repeated itself... I can't get any updates from Tuesday afternoon. Right now my signatures are stuck to:
Virus Identities: 25734
Database Timestamp: Tue Feb 25 16:06:17 2020
According to current.cvd.clamav.net this is not the latest sig.
Running manually /usr/share/clamav/freshclam-sleep does not produce any output, the process seems to hanging... When run by cron and attempted to terminate - goes defunct.
/var/log/freshclam.log is empty.
Running sudo freshclam, gives:
ClamAV update process started at Thu Feb 27 20:06:29 2020
daily.cld is up to date (version: 25734, sigs: 2197156, f-level: 63, builder: raynman)
yum check-update - gives no updates available.
Reboot doesn't seems to solve the situation.
Any help would be appreciated.
exec
or look in to see what and when yum updated.
efa auto-updates, unless you are henk , so don't jump to conclusions.
There will be new clamav versions on a regular basis, the new clamav will be installed automaticly when available in the repo.
Long story short, your efa is up to date
grep -irHn 'clamd' /var/log/messages
/var/log/yum.log
Thank you henk.
I know my efa is up to date - didn't doubt that I do realize that efa is relying on 3rd party repos such as EPEL, and yes I do realize that my clamav is not latest version - all of that is ok for me.
What I don't realize is why freshclam is screwing up... I think even with slightly older version clamav and it's update should work...
Anyway... here some output:
grep -irHn 'clamd' /var/log/messages:
/var/log/messages:11054:Feb 27 19:47:21 host systemd: Started clamd scanner (scan) daemon.
/var/log/messages:11092:Feb 27 20:01:35 host clamd[2619]: SelfCheck: Database modification detected. Forcing reload.
/var/log/messages:11093:Feb 27 20:01:36 host clamd[2619]: Reading databases from /var/lib/clamav
/var/log/messages:11096:Feb 27 20:01:57 host clamd[2619]: Database correctly reloaded (6942267 signatures)
/var/log/messages:11124:Feb 27 20:18:18 host clamd[2619]: SelfCheck: Database status OK.
/var/log/messages:11138:Feb 27 20:28:18 host clamd[2619]: SelfCheck: Database status OK.
/var/log/messages:11198:Feb 27 21:08:40 host clamd[2619]: SelfCheck: Database status OK.
/var/log/messages:11214:Feb 27 21:20:27 host clamd[2619]: SelfCheck: Database status OK.
/var/log/messages:11229:Feb 27 21:32:43 host clamd[2619]: SelfCheck: Database status OK.
cat /var/log/yum.log
Feb 26 09:30:03 Updated: clamav-filesystem.noarch 0.101.5-10.el7
Feb 26 09:30:04 Updated: clamav-update.x86_64 0.101.5-10.el7
Feb 26 09:30:05 Updated: clamav-lib.x86_64 0.101.5-10.el7
Feb 26 09:30:06 Updated: clamd.x86_64 0.101.5-10.el7
Feb 26 09:30:07 Updated: clamav.x86_64 0.101.5-10.el7
Feb 26 09:31:09 Updated: eFa.x86_64 1:4.0.2-8.eFa.el7
Hi Echo,
Freshclam is not screwing up, it just mentions there is a newer version of ClamAV
You can ignore the WARNING: Your ClamAV installation is OUTDATED!
My freshclam manual run
Freshclam logs to /var/log/messages
[root@efa4]# freshclam -v
Current working dir is /var/lib/clamav
ClamAV update process started at Fri Feb 28 10:23:44 2020
Using IPv6 aware code
Max retries == 3
Querying current.cvd.clamav.net
TTL: 1800
Software version from DNS: 0.102.2
main.cvd version from DNS: 59
main.cld is up to date (version: 59, sigs: 4564902, f-level: 60, builder: sigmgr)
daily.cvd version from DNS: 25735
daily.cld is up to date (version: 25735, sigs: 2199661, f-level: 63, builder: raynman)
bytecode.cvd version from DNS: 331
grep -irHn 'freshclam' /var/log/messages
