Many messages have a score 0.
example:
Received: from moon.tipkade.com ([69.94.137.212] [69.94.137.212])
by relay.domain.com (MailScanner Milter) with SMTP id 48Gs2C3Vyxz669C
for <recipient@domain.com>; Tue, 11 Feb 2020 06:37:19 +0100 (CET)
DMARC-Filter: OpenDMARC Filter v1.3.2 relay.domain.com 48Gs2C3Vyxz669C
Authentication-Results: relay.domain.com; dmarc=pass (p=none dis=none) header.from=tipkade.com
Authentication-Results: relay.domain.com; spf=pass smtp.mailfrom=jitkarrfzcyh@tipkade.com
DKIM-Filter: OpenDKIM Filter v2.11.0 relay.domain.com 48Gs2C3Vyxz669C
dkim=pass (1024-bit key) header.d=tipkade.com header.i=jitkarrfzcyh@tipkade.com header.b="Vk4ZNmtN"
Authentication-Results: relay.domain.com; dmarc=fail (p=none dis=none) header.from=tipkade.com
Authentication-Results: relay.domain.com; spf=tempfail smtp.mailfrom=jitkarrfzcyh@tipkade.com
DKIM-Signature: v=1; a=rsa-sha1; c=relaxed/relaxed; s=dkim; d=tipkade.com;
h=Date:To:List-Unsubscribe:Message-ID:Subject:MIME-Version:From:Content-Type:Content-Transfer-Encoding; i=jitkarrfzcyh@tipkade.com;
bh=lUnubupDRN1mEFGXnmOGP9PevYs=;
b=Vk4ZNmtNT3gwW/3cY11AXBKc+nbNeIuHoVMkVSxrSgEdm3iB1uB/nLZKpyZNX0cJHx0gfnauD7gl
7kAykUbURs2rS4mXNLTjxtaKwSBRTYZf7V1W/P6jTDMpxVrHIhfQEJI2p8oFFcAR8tdaf4zKpxRP
gskKpBWKa82neUYYuLI=
Date: Tue, 11 Feb 2020 06:34:26 +0100
To: <recipient@domain.com>
List-Unsubscribe: <http://tipkade.com/ub.php?b=maa48546707 ... 2tway77b5c>
X-Report-Abuse: <http://tipkade.com/aa.php?a=maa48546707 ... 2tway77b5c>
Message-ID: <tkhczatl.mvqjciyienckoullmkaj@dgdd.tipkade.com>
Subject: Chraňte své auto před ledem: ochranná clona na čelní sklo za 329 korun
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary=b1_fc2e8q4cq90wpqxqwtlz9to01fr-oj3QLU82B6; charset="UTF-8"
Content-Transfer-Encoding: 8bit
Spam: N Action(s): store, deliver, header, "X-Spam-Status:No"
High Score Spam: N
SpamAssassin Spam: N
Listed in RBL: N
SPAM Whitelisted: N
SPAM Blacklisted: N
SpamAssassin Autolearn: N
SpamAssassin Score: 0.00
Spam Report:
out timed
Bayes Database Information
Number of Spam Messages: 4,570
Number of Ham Messages: 7,485
Number of Tokens: 138,929
Oldest Token: Tue, 04 Feb 2020 07:40:46 +0100
Newest Token: Tue, 11 Feb 2020 10:19:14 +0100
Last Journal Sync: Thu, 01 Jan 1970 01:00:00 +0100
Last Expiry: Tue, 11 Feb 2020 10:06:35 +0100
Last Expiry Reduction Count: 25,218 tokens
Where is the problem?
thx,
regards,
á
SpamAssassin Score is 0.00
Re: SpamAssassin Score is 0.00
Hi Akos,
Assuming you are on eFa4
Run the mailScanner and Spamassasin Lint tests.
And there are always the log files.
that's looks like a indication for issues to me. Can you update the spamassassin rule descriptions and Update GEOIP via the GUI?Spam Report:
out timed
thx for reply.
I ran all of them except GEOIP (A license key from www.maxmind.com is needed to download GeoLite2 data)
Spamassasin Lint tests is everithing green except dbg: diag: perl platform: 5.016003 linux 1.03142 (yellow)
thx,
á
thx for reply.
thx,
á
To run efa4 everyone needs to get a -free- license from Maxmind viewtopic.php?f=8&t=4068
thx for reply.
maxmind is done
I have changed in MailScanner.conf SpamAssassin Timeout = 75 to 500. I'm testing it now.
we does not have performance problems:
580M /var/lib/mysql/
1.2M /var/lib/mysql/mysql
4.0K /var/lib/mysql/performance_schema
90M /var/lib/mysql/sa_bayes
872K /var/lib/mysql/sqlgrey
128M /var/lib/mysql/mailscanner
36M /var/lib/mysql/opendmarc
0 /var/lib/mysql/temp
Timing cached reads: 9880 MB in 1.99 seconds = 4958.94 MB/sec
Timing buffered disk reads: 3898 MB in 3.00 seconds = 1299.17 MB/sec
thx,
á
thx for reply.
maxmind is done
thx,
á
