Mailscanner not reporting\tracking anything
sunnyg
Post by sunnyg »
I have just completed a fresh installation of EFA4, and I am running into an issue where mailscanner does not seem to be tracking\scanning any incoming or outgoing emails.
I am able to successfully send emails out to the internet and I am able to recieve emails (including spam).
the only configuration changes made after the installation was the configuration of my smtp relay in postfix.
Anythoughts on the possible cause?
thanks in advance
Sunny
hugorosa
Re: Mailscanner not reporting\tracking anything
Post by hugorosa »
I have the same behavior
Did you solved ?
hokage
Post by hokage »
I have same issue but only for outgoing, incoming is working fine
Examine the following /etc/postfix/main.cf
smtpd_milters = ?
If you are missing 127.0.0.1:33333 you have a problem.
hokage
Post by hokage »
smtpd_milters = inet:localhost:8891, inet:localhost:8893, inet:127.0.0.1:33333
here is
hokage wrote: 07 Feb 2020 23:24 I have same issue but only for outgoing, incoming is working fine
This usually indicates that your outbound traffic isn't hitting the eFa and is going straight out to the Internet instead.
