eFa 4 - No LDAP Support in Postfix?
BLinz
Post by BLinz »
as i can see eFa 4 using not the postfix-package from the Centos Repository.
I was trying to activate the LDAP Check in postfix (i am using with eFa 3) but i got the error
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: query_filter=(|(mail=%s)(proxyAddresses=smtp:%s))
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: bind=yes
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: bind_pw=xxxxxx
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: version=3
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: bind_dn=CN=xxxx,OU=xxxx,DC=xxx,DC=xxx
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: server_host=10.100.12.50
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: result_format=OK
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: leaf_result_attribute=mail
/usr/sbin/postconf: warning: ldap:/etc/postfix/ldap_relay_recipient_maps.cf: unused parameter: search_base=DC=xxx, DC=xxx
so i think that postfix have no LDAP support?
There is an extra package for Postfix from CentOS repositories:
postfix32u-ldap
but no
postfix32u_eFa-ldap
or i am doing something wrong/have to change with this postfix version? i read some docs about postfix+ldap i think nothing changed
Best Regards,
BLinz
Re: eFa 4 - No LDAP Support in Postfix?
postfix is compiled with ldap support in eFa4, I believe.
kris240376
Post by kris240376 »
I'm trying to port a config which is known to work from 3.0.2.6 and can confirm. LDAP support is missing from eFa Postfix.
Confirmed that LDAP support is compiled properly in the eFa postfix rpm, but external libraries are required.
Try installing openldap packages to see if library requirements get satisfied.
kris240376
The openldap package is installed but the m4 package is not.
I looked a bit at what can cause this and it seems that this problem can crop up if the machine that the postfix package was built on doesn't have the m4 package <http://postfix.1071664.n5.nabble.com/LD ... 91375.html>.
Good info, I will rebuild with m4 installed.
kris240376
I noticed that there was a rebuild of the postfix-efa package and decided to try my LDAP config again and it works. Thanks for the quick turn around on this.
