Hello all..
I am trying to know how to monitoring of outgoing email
I have seen the EFA only monitor the incoming.
Any docs about this?
thx before
						Outgoing not monitored
Re: Outgoing not monitored
Use EFA as your outgoing mail host and EFA will check your outgoing mail.
I do.
the MX using single MX to EFA. but not monitored
Maybe I am not understanding your question.
If you use EFA as your MX host, then all incoming mail will be monitored by the system.
If you use EFA as your outgoing smarthost, then all your outgoing mail will be monitored by the system.
Perhaps you can explain how your mail system is actually configured?
internet -> EFA -> your actual mail server -> your usersCode: Select all
your users -> your actual mail server -> EFA -> internetRe: Outgoing not monitored
solved sir. thxpdwalker wrote: 08 Feb 2020 11:05 Maybe I am not understanding your question.
If you use EFA as your outgoing smarthost, then all your outgoing mail will be monitored by the system.Code: Select all
Perhaps you can explain how your mail system is actually configured?Code: Select all
What was your problem?
