Getting into console there is an erro
  sudo: /usr/sbin/eFa-Configure: command not found   Code: Select all
Please run this and report back...gregecslo wrote: 11 Jan 2020 08:26 Umm okay....
I did yum update and it found Mailwatch update and bunch of php updates.
Efa is still at 4.0.0
How do we update to 4.0.1 ?
I have repo added in yum repos.
After mailwatch update there are no more messages added to gui.
Also error remains: sudo: /usr/sbin/eFa-Configure: command not found
Any idea?
rpm -qa | grep ^eFa
[root@as ~]# cat /etc/yum.repos.d/eFa4.repo
[eFa4]
name=eFa-Project
baseurl=https://dl.efa-project.org/rpm/eFa4/x86_64
mirrorlist=https://dl.efa-project.org/rpm/eFa4/mirrors-eFa
failovermethod=priority
enabled=1
Dependencies Resolved
 Package                                                           Arch                                              Version                                                        Repository                                          Size
Updating:
 MailWatch                                                         x86_64                                            1:1.2.14-1.eFa.el7                                             eFa4                                               1.3 M
 certbot                                                           noarch                                            1.0.0-1.el7                                                    epel                                                41 k
 microcode_ctl                                                     x86_64                                            2:2.1-53.7.el7_7                                               updates                                            2.5 M
 mod_php72u                                                        x86_64                                            7.2.26-1.el7.ius                                               ius                                                3.1 M
 nss                                                               x86_64                                            3.44.0-7.el7_7                                                 updates                                            854 k
 nss-softokn                                                       x86_64                                            3.44.0-8.el7_7                                                 updates                                            330 k
 nss-softokn-freebl                                                x86_64                                            3.44.0-8.el7_7                                                 updates                                            224 k
 nss-sysinit                                                       x86_64                                            3.44.0-7.el7_7                                                 updates                                             65 k
 nss-tools                                                         x86_64                                            3.44.0-7.el7_7                                                 updates                                            528 k
 nss-util                                                          x86_64                                            3.44.0-4.el7_7                                                 updates                                             79 k
 php72u-cli                                                        x86_64                                            7.2.26-1.el7.ius                                               ius                                                4.8 M
 php72u-common                                                     x86_64                                            7.2.26-1.el7.ius                                               ius                                                1.2 M
 php72u-fpm                                                        x86_64                                            7.2.26-1.el7.ius                                               ius                                                1.6 M
 php72u-gd                                                         x86_64                                            7.2.26-1.el7.ius                                               ius                                                185 k
 php72u-json                                                       x86_64                                            7.2.26-1.el7.ius                                               ius                                                 72 k
 php72u-ldap                                                       x86_64                                            7.2.26-1.el7.ius                                               ius                                                 79 k
 php72u-mbstring                                                   x86_64                                            7.2.26-1.el7.ius                                               ius                                                499 k
 php72u-mysqlnd                                                    x86_64                                            7.2.26-1.el7.ius                                               ius                                                241 k
 php72u-pdo                                                        x86_64                                            7.2.26-1.el7.ius                                               ius                                                133 k
 php72u-process                                                    x86_64                                            7.2.26-1.el7.ius                                               ius                                                 88 k
 php72u-xml                                                        x86_64                                            7.2.26-1.el7.ius                                               ius                                                211 k
 python-requests                                                   noarch                                            2.6.0-8.el7_7                                                  updates                                             95 k
 python2-acme                                                      noarch                                            1.0.0-1.el7                                                    epel                                                74 k
 python2-certbot                                                   noarch                                            1.0.0-1.el7                                                    epel                                               358 k
 python2-certbot-apache                                            noarch                                            1.0.0-1.el7                                                    epel                                               107 k
 tnef                                                              x86_64                                            1.4.18-1.el7                                                   epel                                                56 k
sudo yum install eFa
[root@as ~]# sudo yum install eFa
Loaded plugins: fastestmirror
 * base: mirror.easyname.at
 * eFa4: dl.efa-project.org
 * epel: mirror.euserv.net
 * extras: mirror.easyname.at
 * updates: ftp.arnes.si
Package 1:eFa-4.0.1-8.eFa.el7.x86_64 already installed and latest version
Nothing to do
[root@as ~]# yum update
No packages marked for updateCode: Select all
[root@as ~]# rpm -qa | grep ^eFa
eFa-base-4.0.0-1.eFa.el7.x86_64
eFa-4.0.1-8.eFa.el7.x86_64Code: Select all
---        Welcome to the eFa Configuration program        ---
---               https://www.efa-project.org              ---
You are currently running eFa-4.0.0.
Please choose an option:
0) Logout from ssh                    9)  MariaDB Recovery
1) Shell                              10) Apache Settings
2) Reboot system                      11) Virus Settings
3) Halt system                        12) System Restore
4) IP Settings                        13) Update Now
5) Tunables                           14) Maintenance Mode
6) MailWatch Settings                 15) Let's Encrypt
7) Mail Settings                      16) DKIM and DMARC
8) Spam Settings                      17) Webmin
[eFa] :
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.0.sh
sudo ./update-4.0.0.sh
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.1.sh
sudo ./update-4.0.1.sh
echo "eFa-4.0.1" > /etc/eFa-Version
