Getting into console there is an erro
sudo: /usr/sbin/eFa-Configure: command not found
Please run this and report back...gregecslo wrote: 11 Jan 2020 08:26 Umm okay....
I did yum update and it found Mailwatch update and bunch of php updates.
Efa is still at 4.0.0
How do we update to 4.0.1 ?
I have repo added in yum repos.
After mailwatch update there are no more messages added to gui.
Also error remains: sudo: /usr/sbin/eFa-Configure: command not found
Any idea?
rpm -qa | grep ^eFa
[root@as ~]# cat /etc/yum.repos.d/eFa4.repo
[eFa4]
name=eFa-Project
baseurl=https://dl.efa-project.org/rpm/eFa4/x86_64
mirrorlist=https://dl.efa-project.org/rpm/eFa4/mirrors-eFa
failovermethod=priority
enabled=1
Dependencies Resolved
Package Arch Version Repository Size
Updating:
MailWatch x86_64 1:1.2.14-1.eFa.el7 eFa4 1.3 M
certbot noarch 1.0.0-1.el7 epel 41 k
microcode_ctl x86_64 2:2.1-53.7.el7_7 updates 2.5 M
mod_php72u x86_64 7.2.26-1.el7.ius ius 3.1 M
nss x86_64 3.44.0-7.el7_7 updates 854 k
nss-softokn x86_64 3.44.0-8.el7_7 updates 330 k
nss-softokn-freebl x86_64 3.44.0-8.el7_7 updates 224 k
nss-sysinit x86_64 3.44.0-7.el7_7 updates 65 k
nss-tools x86_64 3.44.0-7.el7_7 updates 528 k
nss-util x86_64 3.44.0-4.el7_7 updates 79 k
php72u-cli x86_64 7.2.26-1.el7.ius ius 4.8 M
php72u-common x86_64 7.2.26-1.el7.ius ius 1.2 M
php72u-fpm x86_64 7.2.26-1.el7.ius ius 1.6 M
php72u-gd x86_64 7.2.26-1.el7.ius ius 185 k
php72u-json x86_64 7.2.26-1.el7.ius ius 72 k
php72u-ldap x86_64 7.2.26-1.el7.ius ius 79 k
php72u-mbstring x86_64 7.2.26-1.el7.ius ius 499 k
php72u-mysqlnd x86_64 7.2.26-1.el7.ius ius 241 k
php72u-pdo x86_64 7.2.26-1.el7.ius ius 133 k
php72u-process x86_64 7.2.26-1.el7.ius ius 88 k
php72u-xml x86_64 7.2.26-1.el7.ius ius 211 k
python-requests noarch 2.6.0-8.el7_7 updates 95 k
python2-acme noarch 1.0.0-1.el7 epel 74 k
python2-certbot noarch 1.0.0-1.el7 epel 358 k
python2-certbot-apache noarch 1.0.0-1.el7 epel 107 k
tnef x86_64 1.4.18-1.el7 epel 56 k
sudo yum install eFa
[root@as ~]# sudo yum install eFa
Loaded plugins: fastestmirror
* base: mirror.easyname.at
* eFa4: dl.efa-project.org
* epel: mirror.euserv.net
* extras: mirror.easyname.at
* updates: ftp.arnes.si
Package 1:eFa-4.0.1-8.eFa.el7.x86_64 already installed and latest version
Nothing to do
[root@as ~]# yum update
No packages marked for update
[root@as ~]# rpm -qa | grep ^eFa
eFa-base-4.0.0-1.eFa.el7.x86_64
--- Welcome to the eFa Configuration program ---
--- https://www.efa-project.org ---
You are currently running eFa-4.0.0.
Please choose an option:
0) Logout from ssh 9) MariaDB Recovery
1) Shell 10) Apache Settings
2) Reboot system 11) Virus Settings
3) Halt system 12) System Restore
4) IP Settings 13) Update Now
5) Tunables 14) Maintenance Mode
6) MailWatch Settings 15) Let's Encrypt
7) Mail Settings 16) DKIM and DMARC
8) Spam Settings 17) Webmin
[eFa] :
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.0.sh
sudo ./update-4.0.0.sh
wget https://raw.githubusercontent.com/E-F-A/v4/master/rpmbuild/SOURCES/eFa-4.0.1/updates/update-4.0.1.sh
sudo ./update-4.0.1.sh
echo "eFa-4.0.1" > /etc/eFa-Version
