EFA MArks outbound DMARC as bad file
netris
Post by netris »
I am having an issue all of a sudden where the DMARC emails being sent by EFA are being marked bad and that they have a bad file attachment. It was running just fine since the RC, but this started about a month ago....
Re: EFA MArks outbound DMARC as bad file
Does your /etc/MailScanner/filename.rules look like this?
From:   127.0.0.1       /etc/MailScanner/filename.rules.allowall.conf
From:   ::1     /etc/MailScanner/filename.rules.allowall.conf
FromOrTo:       default /etc/MailScanner/filename.rules.conf
netris
Post by netris »
Sorry about not responding sooner. I never got notification of your response and then went out of town for a bit. My /etc/MailScanner/filename.rules is as follows:
netris
Post by netris »
I unfortunately do not have a way to manually implement/test the fix currently, so I'll patiently wait for an update (or until I'm back if the update hasn't installed by then)
Currently in testing, we are working out a few issues with the new spamassassin in test right now and should have this in next release.
netris
Post by netris »
Wonderful! Thank you so much!
