Show current settings + Option for Cancel
Mesomorf
Post by Mesomorf »
Why is it that you can´t see the ENABLED / DISABLED status on every option when you are adjusting things?
The "Toggle Greylisting" setting have a indicator telling me: "Greylisting is currently DISABLED"
..so here I can see it
The "Spam settings" setting does NOT show me ENABLED / DISABLED status.
.. so here (and alot of other places) I can't see it.
And for the y/N/c options that exists sometimes and sometimes you are just FORCED to make a choice (no Cancel existing)
..is it just me that finds all this hard to use?
Example: You don't know your currents settings and but you want to find out. Then you try see what was under that option but you only get greeted make a choice for something that is already ENABLED or DISABLED, you still don't know the current setting.
Am I missing something?
