EFA4 - Can Centos 8 be used
sunnyg
Post by sunnyg »
Does anyone know if CentOs 8 can be used instead of CentOs 7?
Re: EFA4 - Can Centos 8 be used
Probably not, as the EFA build depends on the packages in Centos 7.
The next version will support Centos 8
You can see the discussion about this here: viewtopic.php?f=5&t=1038&p=14763&hilit=Centos+8#p14763
