Is it possible to install this solution on a 3rd party linux webhost. I currently have service with digitalocean.com and they do not support ovh or iso. Is there a way for me to do it manually on my own server?
If there is not a way to do it like this can anyone recommend a good hosting provider I can install this on?
Thank you all in advance for your help.
Poslible to Install on a linux virtual server
Re: Poslible to Install on a linux virtual server
I did this with some help, see here: http://forum.efa-project.org/viewtopic.php?f=14&t=458
Can I do a manual build on a VPS without Kickstart?
I don't have Iso mounting access. Just root access to VPS
Yes.
Mimic the settings in the ks.cfg file manually (storage, packages, etc., default EFA password, etc.)
Then launch the build script as shown at the end of ks.cfg
You can check vultr hosting
They offer ISO mount to VPS.
viktorokiro
Yes, it is possible to install on a Linux virtual server, you can get tutorial on YouTube channels.
