SQLgrey encountered an SQL error ...
(SOLVED) Re: SQLgrey encountered an SQL error ...
Post by nicola.piazzi » 09 Apr 2019 08:05
USE sqlgrey;
SHOW VARIABLES LIKE '%collation%';
| Variable_name | Value |
| collation_connection | utf8_general_ci |
| collation_database | latin1_swedish_ci |
| collation_server | utf8mb4_unicode_ci |
As you can see sqlgrey create its own database in latin1 but now with mariadb EFA uses utf8 connection, this give the error : Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (utf8mb4_general_ci,COERCIBLE)
Other DB in EFA are altrady utf8
We need to change database, but also tables and columns to be compatible with connection
Here sequence , worked for me
You can do it without problem
mysql -u root -pXXXXXXXXXXXXXX
USE sqlgrey;
ALTER DATABASE sqlgrey CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE config CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE connect CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE domain_awl CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE from_awl CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optin_domain CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optin_email CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optout_domain CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optout_email CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE config MODIFY parameter varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE config MODIFY value varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY sender_name varchar(64) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY sender_domain varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY src varchar(39) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY rcpt varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE domain_awl MODIFY sender_domain varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE domain_awl MODIFY src varchar(39) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl MODIFY sender_name varchar(64) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl MODIFY sender_domain varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl MODIFY src varchar(39) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optin_domain MODIFY domain varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optin_email MODIFY email varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optout_domain MODIFY domain varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optout_email MODIFY email varchar(255) CHARACTER SET utf8 COLLATE utf8_unicode_ci;
gh0stwizard
Re: (SOLVED) Re: SQLgrey encountered an SQL error ...
Post by gh0stwizard » 16 Jul 2019 08:54
nicola.piazzi wrote:
09 Apr 2019 08:05
Thank you! This works for me too.
brock
Post by brock » 27 Aug 2019 07:51
Many thanks, this work for me too.
Post by pdwalker » 21 Oct 2019 03:31
Nicola to the rescue, yet again!
