I would like to know that when I try to check message viewer its shows only Received on: Received by: Received from: only. No message header like things. I tried to dig out the issue but invain and decided to ask from you guys.
Looking forward
Message Viewer
Re: Message Viewer
This has to do with the outdated GeoIP base.
Download a newer version.
See this topic: viewtopic.php?f=13&t=3311
Re: Message Viewer
No luck, cause I have already done this.brunok wrote: 29 Jul 2019 13:12 This has to do with the outdated GeoIP base.
Re: Message Viewer
Can anyone has some solution to this?
Re: Message Viewer
Check this solution here. I had exactly same problem as you and it has already been discussed and worked for me.
viewtopic.php?f=13&t=3677&p=14585#p14585
Re: Message Viewer
Thanks indeed to you for solving my problem, highly appreciated. Although I have done it before but the directed GEO IP Zip file made my day.maxkmv wrote: 22 Aug 2019 10:46 Check this solution here. I had exactly same problem as you and it has already been discussed and worked for me.
