Just received the following cron job email which seems to imply that the new package did not install because it's not signed.
/etc/cron.daily/0yum-daily.cron:
Package eFa-4.0.0-66.eFa.el7.x86_64.rpm is not signed
The following updates will be applied on efa.ihtfp.org:
Package Arch Version Repository Size
Updating:
eFa x86_64 1:4.0.0-66.eFa.el7 eFa4-Testing 92 k
Transaction Summary
Upgrade 1 Package
Updates failed to install with the following error message:
Re: Package eFa-4.0.0-66.eFa.el7.x86_64.rpm is not signed
Yep, broken at the moment, working on getting it resolved.
