Message Viewer
fakhar.khan
Message Viewer
Post by fakhar.khan »
I would like to know that when I try to check message viewer its shows only Received on: Received by: Received from: only. No message header like things. I tried to dig out the issue but invain and decided to ask from you guys.
Looking forward
brunok
Re: Message Viewer
Post by brunok »
This has to do with the outdated GeoIP base.
Download a newer version.
See this topic: viewtopic.php?f=13&t=3311
fakhar.khan
Re: Message Viewer
brunok wrote: 29 Jul 2019 13:12 This has to do with the outdated GeoIP base.
No luck, cause I have already done this.
fakhar.khan
Re: Message Viewer
Can anyone has some solution to this?
maxkmv
Re: Message Viewer
Post by maxkmv »
Check this solution here. I had exactly same problem as you and it has already been discussed and worked for me.
viewtopic.php?f=13&t=3677&p=14585#p14585
fakhar.khan
Re: Message Viewer
maxkmv wrote: 22 Aug 2019 10:46 Check this solution here. I had exactly same problem as you and it has already been discussed and worked for me.
Thanks indeed to you for solving my problem, highly appreciated. Although I have done it before but the directed GEO IP Zip file made my day.
