USE sqlgrey;
SHOW VARIABLES LIKE '%collation%';
| Variable_name        | Value              |
| collation_connection | utf8_general_ci    |
| collation_database   | latin1_swedish_ci  |
| collation_server     | utf8mb4_unicode_ci |
As you can see sqlgrey create its own database in latin1 but now with mariadb EFA uses utf8 connection, this give the error : Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (utf8mb4_general_ci,COERCIBLE)
Other DB in EFA are altrady utf8
We need to change database, but also tables and columns to be compatible with connection
Here sequence , worked for me
You can do it without problem
mysql -u root -pXXXXXXXXXXXXXX
USE sqlgrey;
ALTER DATABASE sqlgrey CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE config CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE connect CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE domain_awl CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE from_awl CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optin_domain CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optin_email CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optout_domain CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE optout_email CHARACTER SET 'utf8mb4' COLLATE 'utf8mb4_unicode_ci';
ALTER TABLE config MODIFY parameter  varchar(255)  CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE config MODIFY value      varchar(255)  CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY sender_name    varchar(64)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY sender_domain  varchar(255)   CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY src            varchar(39)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE connect MODIFY rcpt           varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE domain_awl       MODIFY sender_domain  varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE domain_awl       MODIFY src            varchar(39)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl       MODIFY sender_name    varchar(64)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl       MODIFY sender_domain  varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE from_awl       MODIFY src            varchar(39)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optin_domain  MODIFY domain            varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optin_email  MODIFY email            varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optout_domain  MODIFY domain            varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
ALTER TABLE optout_email  MODIFY email            varchar(255)    CHARACTER SET utf8 COLLATE utf8_unicode_ci;
						SQLgrey encountered an SQL error ...
				gh0stwizard
Re: (SOLVED) Re: SQLgrey encountered an SQL error ...
Thank you! This works for me too.
Many thanks, this work for me too.
Nicola to the rescue, yet again!
