I’ve got a problem with archives. Recent I’ve got e-mail with virus inside rar archive. After some tests I found that MailScaner won’t scan archives wich contains spaces in name. For example, if I put notepad.exe in archive with name “notepad.rar” MailScanner blocks it, because archive contains executable file. But if I put the same notepad.exe in archive named “my favorite notepad.rar” MailScanner will pass it trough.
Do you have any idea how to fix it?
Some dangerous files can pass trough (spaces in filenames)
Re: Some dangerous files can pass trough (spaces in filenames)
Problem solved with MailScanner update
Can you post more details about how you updated MailScanner?
not solved
viewtopic.php?f=13&t=3628
[root@mx1 etc]# EFA-Update -check
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are already running version EFA-3.0.2.6, no update needed
Please plan on moving to v4. v4 is in RC3 and will be RTM soon.
Is there a migration path yet?
Thanks Shawn.
This is clearly a weekend job.
