hardware requirements
Testing of eFa 4
stefandewal
Post by stefandewal » 06 May 2019 14:26
Hi there,
We do about 100000 e-mails a day. Does anyone have a suggestion for hardware requirements?
ethandee178
Re: hardware requirements
Post by ethandee178 » 06 May 2019 18:17
Do you mean 100k delivered clean messages? Or 100k new mails regardless of status?
stefandewal
Post by stefandewal » 07 May 2019 07:34
Around total 100000.
ethandee178
Post by ethandee178 » 08 May 2019 19:25
At 10-20k messages a day, I run 8 cores 16G of ram and 200G of disk space.
Load average is around 1.
I think I could probably double that and still be fine.
I would highly recommend SSD storage for the db though.
stefandewal
Post by stefandewal » 13 May 2019 09:56
Currently the machine doing the mailscanning is also the imap/pop server which does 5 consecutive logins per second.
It runs clamav/amavisd/spamd/cyrus/postfix on an average load of 4.
The hardware specs are 8 cores and 16gb of memory.
I will start our dedicated efa with the same specs and see what it brings from there.
thanks for the advice.
jamerson
Post by jamerson » 02 Aug 2019 12:54
we are delevering aboout 500k a day.
have loadbalancing EFA ( 2 EFA ) I7/4GB each both are working fine.
