Releasing from the quaratine email
Previously with ESVA system if you clicked on a message from the emailed quarantine report, it used to display just that message where I could check whether I want to release it or not. Now when I click on a message it takes me to the whole list instead. Is there any way I can change this?
Re: Releasing from the quaratine email
When I am logged into EFA and click View in the Quarantine report, it takes me to the message.
However, if I am not logged into EFA, it takes me to the message list.
I wonder if some kind of redirect after login might be needed for this?
I am finding exactly the same. So all we need now is a solution.
Was a solution ever found for this?
Our customers are sick of the per message emails & would like to use the Quarantine emails instead, but this makes them pretty much unusable.
Josh
Josh
It's been a while now and still no fix. I've just seen this
Manuel Dalla Lanaendelwar removed the bug label on 12 Aug
Manuel Dalla Lanaendelwar added this to the v1.2.0 milestone on 12 Aug
So does it mean that it has been fixed in Mailwatch now or what?
Looks like it is still open. So I would guess it is not resolved.
- Socal_Steve
I'm having this issue as well. I wonder if there is a way to just hard code the user and password into the users quarantine report link? Does this make sense? I know it would be a little insecure but at least it would work for now.
STEVE
STEVE
Same here. User don't want to have to logon.
I will check on status of issue with MailWatch devs and see what we have available now...
Awesome, thank you
Looks like issue is still open on mailwatch....
I think we need to implement this ourselves. I'll have to study the mailwatch code and see what I can do...
Hi guys,
I've released a fix to this issue on github, please test this implementation and report any further issue.
Manuel
Manuel
Thank you kind sir. We will test
- Socal_Steve
I don't see anything on Git?? Am i blind?
MailWatch project.
- Socal_Steve
Thanks. Will check it out.shawniverson wrote:MailWatch project.
- Socal_Steve
...figured out how Git works and have made the changes. will post progress soon.
- Socal_Steve
Okay working for the user after they login now as it redirects to the link that was clicked. this is great however this was not the functionality i was looking for. I'm looking for once the user clicks the link no login is needed to see the spam message and release it.
If you want this feature, I will need your help figuring this out.Socal_Steve wrote:I'm looking for once the user clicks the link no login is needed to see the spam message and release it.
I do not see an obvious or immediate way to do this in a way that does not break the security of MailWatch.
On my old ESVA 2.0.0.5 system I can confirm that the user does have to log in when clicking the links from the quarantine email, and it would then take them directly to the message. The return of that functionality would definitely be appreciated. It sounds like EndelWar's fix is the answer.
