Default configure options.
In the process of testing efa4 there are some major questions to answer, besides the customer specific part.
1. Use Ipv6 yes/no
2. Use recursion yes/no
3. Use efa only inbound yes/no
4. Use greylisting yes/no
5. Install additional options ( webmin, letsencrypt, etc)
6. Install additional packages. ( mc, bacula-client, xymon-client, etc)
7. Configure selinux and Firewalld based on above options
Besides how you want to use efa, the first 3 options will affect your config.
I would like to install dkim, dmarc as option, see point 3, or as a separate configure option. see point 5
I do realize the need to freeze efa4 development, to be able to launch the new efa4 version. :oops:
Would like to know the opinion of other members ( using efa only inbound) on this.
toddh
Re: Default configure options.
Post by toddh »
Answers for our environment
1. Use Ipv6 - No
2. Use recursion - No (having problems with it here)
3. Use efa only inbound - Yes
4. Use greylisting - Yes!
5. Install additional options ( webmin, letsencrypt, etc) I am fine with the option to install these later, not during initial setup
6. Install additional packages. ( mc, bacula-client, xymon-client, etc) Check_mk and Nagios clients.
7. Configure selinux and Firewalld based on above options Yes
Todd
stefandewal
Post by stefandewal »
1. Use Ipv6 - Yes
2. Use recursion - Yes
4. Use greylisting - No
5. Install additional options No
6. Install additional packages. (several minor packages from epel/centos)
Stefan
Reading back my own post, I see the need for some additional info :shifty:
The main reason for this post was to install dkim/dmarc as an option, if you use efa inbound only.
No clou how many members use efa inbound and outbound or just for inbound mail only.
tesme33
Post by tesme33 »
henk wrote: 14 Mar 2019 10:30 Reading back my own post, I see the need for some additional info :shifty:
I know its late to answer.
But i use it in- and outbound.
Yours
