razor2 report failed
doggy101
Post by doggy101 »
Hi All,
I'm running latest version of EFA (B3) on a virtual machine.
When I manually want to add a message to the spam database i get an error
warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 176. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Plugin/Razor2.pm line 329., 1 message(s) examined.
this is shown after you add it on the end of the message detailpage
Re: razor2 report failed
doggy101
Post by doggy101 »
Not the same, this is an install from scratch on a new system (virtualized by Leaseweb)
aro_bpaillc
Post by aro_bpaillc »
anybody came up with the solution? struggling with same issue.
Have a look at this post. viewtopic.php?t=3856
Read the entire post and check the missing spamassassin symlink.
TFNcap
Post by TFNcap »
this answer is not about solution
but
I was having the same problem
solutions didn't work well for me
was working later
I hope your problem will be solved
eFa-4.0.2 - ©
What do you mean with ' not about solution' :?:
Please do not add non info to a post.
