Let's Encrypt Cert Renewals Email
bob.lenz
Post by bob.lenz »
Hello! I'm receiving the following email regarding Let's Encrypt and the certificate no longer working in my EFA Project Box (3.0.2.6) after Feb 13. Any ideas on how to fix this so the EFA box will request the proper certificate type? Thanks!
Action may be required to prevent your Let's Encrypt certificate renewals from breaking.
If you already received a similar e-mail, this one contains updated information.
Your Let's Encrypt client used ACME TLS-SNI-01 domain validation to issue a certificate in the past 60 days. Below is a list of names and IP addresses validated (max of one per account):
DNS Domain Name (IP Address) on 2018-12-08
TLS-SNI-01 validation is reaching end-of-life. It will stop working temporarily on February 13th, 2019, and permanently on March 13th, 2019.
Any certificates issued before then will continue to work for 90 days after their issuance date.
You need to update your ACME client to use an alternative validation method (HTTP-01, DNS-01 or TLS-ALPN-01) before this date or your certificate renewals will break and existing certificates will start to expire.
Our staging environment already has TLS-SNI-01 disabled, so if you'd like to test whether your system will work after February 13, you can run against staging: https://letsencrypt.org/docs/staging-environment/
If you're a Certbot user, you can find more information here:
https://community.letsencrypt.org/t/how ... tbot/83210
Our forum has many threads on this topic. Please search to see if your question has been answered, then open a new thread if it has not:
For more information about the TLS-SNI-01 end-of-life please see our API
announcement:
https://community.letsencrypt.org/t/feb ... port/74209
Thank you,
Let's Encrypt Staff
roni77
Re: Let's Encrypt Cert Renewals Email
Post by roni77 »
You should be able to change this in the file /usr/local/sbin/EFA-Renew-Certs.
bob.lenz
Post by bob.lenz »
Unfortunately, I do not see anything talking about the encryption level in this script.
RampantTech
Post by RampantTech »
HI All
Did anyone ever work this out?
This thread just stops at nothing
I need to fix the same issue
Some direction would be great
bob.lenz
Post by bob.lenz »
Unfortunately, I do not have a solution yet. I was hoping someone could give direction here. We can't be the only two with this issue. Let's Encrypt documentation on certbot did not lead me anywhere as it doesn't seem to follow Let's Encrypt's rules although I did find out that they require version 0.28 and EFA seems to be running on 0.20 currently. Worried about updating it and breaking something else with SSL.
RampantTech
HI All,
I am presuming that the statement in the Cert Bot Auto file in /opt/certbot/certbot-auto answers our questions
Comment at top of the file reads
Download and run the Latest version of the Certbot Client
Note this script is auto generated and Self Updating
If you want to edit it locally please run with the --no-self-upgrade FLAG
So I am presume that the CertBot client will auto upgrade itself when necessary
Can anyone validate this statement for me?
Gspearson
Post by Gspearson »
What I have done is on version EFA-3.0.2.6 is login to console
run yum update (At time I did this today, had 216 updates to perform)
Then I ran certbot-auto renew which then upgraded certbot 0.21 to 0.32.0 and when completed. This then used the HTTP-01 validation method
Graham Pearson
Your Coldfusion Professional
Goshen, IN 46528
http://www.yourcfpro.com
bob.lenz
Post by bob.lenz »
That did the trick for me! Thanks for the help, Gspearson
Here's a complete list of what I did:
Go to Shell
su
yum update --yes to all updates
cd /opt/certbot
./certbot-auto renew
exit
w_bufffet
Post by w_bufffet »
Confirming same issue, last post resolved it!
thank you
