Email Details Invisible
omer
Post by omer »
Hello
I've seen e-mails before. All header information seemed. But I haven't seen the details in two days. How can I solve this problem?
iglooo
Re: Email Details Invisible
Post by iglooo »
You mean message details on mailwatch? It might be this if you're running version 3 - viewtopic.php?f=13&t=3311
What changed two days ago?
(added the image that was not visible on the first post)
omer
Post by omer »
I did the GeoIP database update two days ago.
omer
Post by omer »
I've changed the GeoIP.dat files at this location and it's working right now.
Thank you so much.
/usr/share/GeoIP/GeoIP.dat
/var/www/html/mailscanner/temp/GeoIP.dat
