When manually sending the quarantine report i get this error:
An error occured while sending the quarantine report.
I see nothing strange in apache error log, postfix log or php-fpm log
Does anyone have any ideas?
[SOLVED] An error occured while sending the quarantine report.
Re: An error occured while sending the quarantine report.
Sounds like a SELinux denial.
If you try this and send the message, do you get some interesting output?
sudo tail -f /var/log/audit/audit.log | grep -i denied
shawn, i found it. it was really simple. i edited conf.php en set debug to true
after that i saw that i edited postfix a bit to much.
i only let postfix listen on 2 wan ip adresses and not localhost
So mailwatch couldnt connect to localhost
