ERROR: buildcld: Can't add daily.hsb to new daily.cld - please check if there is enough disk space available
jamerson
Post by jamerson »
Hi Guys,
Probably you have noticed from the last day update, the EFA should sent a email with the below warning
ERROR: buildcld: Can't add daily.hsb to new daily.cld - please check if there is enough disk space available, clam is giving a stupid reason
ERROR: Can't create local database
the solution is simple
run this command in the terminal
sudo freshclam
after it finishes. probably will show a error run the next
sudo rm /var/lib/clamav/daily.cld
last command
sudo freshclam
you should be set now.
if you have any questions, let us know.
have a spammy day
