EFA 4 beta
jamerson
Re: EFA 4 beta
Post by jamerson »
henk wrote: 21 Jan 2019 20:38
jamerson wrote: 21 Jan 2019 14:54 I Dont know what happens but i am missing the button Greylist after today
Emails are arriving no problem, just the button is disapeared.
i've tried to restart the
sudo systemctl start sqlgrey
and even restart but nothing helps.
I have the same issue, no errors whatsover. Did you also run yum update today?
yes, yesterday we fixed some repo and had to upload the new repo with yum update.
the MailWatch update overwrote functions.php a new update will be released tonight so you the issue will be fixed.
Re: EFA 4 beta
This missing greylist came from yesterday's update, so, I added it to the issue list and and going to prepare a fix
Re: EFA 4 beta
Just found this about rpc bind
https://access.redhat.com/solutions/2798411
dracut -v -f
systemctl reboot
systemctl status rpcbind.socket
About sqlgrey
in maillog
Jan 21 21:42:56 sansspam sqlgrey: Couldn't unlink "/var/run/sqlgrey.pid" [Permission denied]
Jan 21 21:45:30 sansspam sqlgrey: Process Backgrounded
Jan 21 21:49:41 sansspam sqlgrey: dbaccess: can't connect to DB: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2 "No such file or directory")
Jan 21 21:49:41 sansspam sqlgrey: dbaccess: error: couldn't get now() from DB: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2 "No such file or directory")
Jan 21 21:49:41 sansspam sqlgrey: dbaccess: error: couldn't access config table: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2 "No such file or directory")
[root@sansspam mysql]# systemctl status sqlgrey
● sqlgrey.service - SQLgrey Postfix Grey-listing Policy service
Loaded: loaded (/usr/lib/systemd/system/sqlgrey.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2019-01-21 22:26:08 CET; 6min ago
Process: 5304 ExecStart=/usr/sbin/sqlgrey -d (code=exited, status=0/SUCCESS)
Main PID: 5680 (sqlgrey)
CGroup: /system.slice/sqlgrey.service
└─5680 /usr/bin/perl -w /usr/sbin/sqlgrey -d
Jan 21 22:26:08 sansspam.private.lan sqlgrey[5680]: Process Backgrounded
Jan 21 22:26:08 sansspam.private.lan sqlgrey[5680]: 2019/01/21-22:26:08 sqlgrey (type Net::Server::Multiplex) starting! pid(5680)
Jan 21 22:26:08 sansspam.private.lan sqlgrey[5680]: Binding to TCP port 2501 on host 127.0.0.1 with IPv4
Jan 21 22:26:08 sansspam.private.lan sqlgrey[5680]: Setting gid to "989 989"
Jan 21 22:26:08 sansspam.private.lan sqlgrey[5680]: Setting uid to "992"
Jan 21 22:26:08 sansspam.private.lan systemd[1]: Started SQLgrey Postfix Grey-listing Policy service.
Jan 21 22:26:09 sansspam.private.lan sqlgrey[5680]: dbaccess: can't connect to DB: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2 "No suc...directory")
Jan 21 22:26:09 sansspam.private.lan sqlgrey[5680]: dbaccess: error: couldn't get now() from DB: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.so...directory")
Jan 21 22:26:09 sansspam.private.lan sqlgrey[5680]: dbaccess: error: couldn't access config table: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql....directory")
Hint: Some lines were ellipsized, use -l to show in full.
Check mysqlserver
I noticed the mysql settings twice in mariadb-server.cnf. I do not remember adding parameters manual, can you check this in your build?
mariadb-server.cnf
Notice the space on position 1
# This group is only read by MariaDB-10.1 servers.
# If you use the same .cnf file for MariaDB of different versions,
# use this group for options that older servers don't understand
[mariadb-10.1]
innodb-defragment = 1
innodb_buffer_pool_instances = 1
innodb_buffer_pool_size = 1G
innodb_file_per_table = 1
innodb_log_buffer_size = 32M
innodb_log_file_size = 125M
join_buffer_size = 512K
key_cache_segments = 4
max_allowed_packet = 16M
max_heap_table_size = 32M
query_cache_size = 0M
query_cache_type = OFF
read_buffer_size = 2M
read_rnd_buffer_size = 1M
skip-external-locking
skip-host-cache
sort_buffer_size = 4M
thread_cache_size = 16
tmp_table_size = 32M
bind-address = 127.0.0.1
skip-host-cache
I just Shawn's post about the issue, but still it usefull info, I think ;)
I will be back,tomorrow.
Re: EFA 4 beta
Also build/update related and will include fixes.
Alleyviper
Re: EFA 4 beta
Post by Alleyviper »
Hi there,
Are updates to the build available with yum update?
Re: EFA 4 beta
Alleyviper
Re: EFA 4 beta
Alleyviper wrote: 21 Jan 2019 22:51 Hi there,
Got it
Note: yum update and yum-cron are now being tested moving forward in the testing repo.
jamerson
Re: EFA 4 beta
Post by jamerson »
after the update of 22 jan 2019 ( included CLAM AV ) see below, emails are delayet released and the greylist is holding like 130 emails for over 24 hr and did not released them yet.
what i noticed is the Clam Av version is not showen on the services
MailWatch Version: 1.2.12
MailScanner Version: 5.1.3
ClamAV Version:
SpamAssassin Version: 3.4.2
PHP Version: 7.2.14
MySQL Version: 10.1.35-MariaDB
GeoIP Database Version: GeoLite2 Country database 2019-01-15 16:42:37
Re: EFA 4 beta
Looks like a clam update came down and reset permissions on the /var/run/clamd.scan :think:
Rebooting takes care of it, but that another thing that needs fixed...
jamerson
Re: EFA 4 beta
Post by jamerson »
shawniverson wrote: 22 Jan 2019 11:32 Looks like a clam update came down and reset permissions on the /var/run/clamd.scan :think:
Hi Shwniverson,
i've rebooted the box but it still the same, emails hangs there now forever :)
Alleyviper
Re: EFA 4 beta
Hi there,
Had the same issue and detected the same thing :ugeek:
jamerson
Re: EFA 4 beta
Post by jamerson »
Alleyviper wrote: 22 Jan 2019 11:37 Hi there,
rebooting the box appear to fix it, however it will be fixed in the next
yum-updates
Alleyviper
Re: EFA 4 beta
Hi there,
But yum updates are already available?
Checked. Not yet :naughty:
jamerson
Re: EFA 4 beta
Post by jamerson »
Alleyviper wrote: 22 Jan 2019 12:12 Hi there,
they are not yet availble, probably tonight.
Re: EFA 4 beta
I reverted the yum update from yesterday. Changed the next things ending up in a working version
One error left: Jan 22 16:34:07 sansspam sqlgrey: Couldn't unlink "/var/run/sqlgrey.pid" [Permission denied])
1. Change user apache to php-fpm in sudoers ( commit 12ae1becaea958f5f206b59667d2b996659edf2b on github)
sed -i 's/apache/php-fpm/' /etc/sudoers.d/mailwatch
2. Set dependency on mariadb.service for sqlgray
/etc/systemd/system/multi-user.target.wants/sqlgrey.service
[Unit]
Description=SQLgrey Postfix Grey-listing Policy service
After=syslog.target network.target mariadb.service
[Service]
Type=forking
PIDFile=/var/run/sqlgrey.pid
[Install]
WantedBy=multi-user.target
3. Set dependency on mailscanner.service for msmilter.service
/etc/systemd/system/multi-user.target.wants/msmilter.service
[Unit]
Description=LSB: MSMilter daemon
Documentation=man:systemd-sysv-generator(8)
SourcePath=/usr/lib/MailScanner/init/msmilter-init
After=network-online.target remote-fs.target rsyslog.service mailscanner.service
Wants=network-online.target
[Service]
Type=forking
Restart=no
TimeoutSec=1min
IgnoreSIGPIPE=no
KillMode=process
GuessMainPID=no
RemainAfterExit=yes
ExecStart=/usr/lib/MailScanner/init/msmilter-init start
ExecStop=/usr/lib/MailScanner/init/msmilter-init stop
EnvironmentFile=-/etc/MailScanner/defaults
PIDFile=/var/run/MSMilter.pid
[Install]
4. Change root to valid user in aliases
/etc/aliases
# Basic system aliases -- these MUST be present.
mailer-daemon: postmaster
#postmaster: root
postmaster: validuser@yourdomain.lan
make active
newaliases
5. Needed to fix the rpc-bind issue, since I reverted the updates from yesterday.
systemctl daemon-reload
dracut -v -f  && systemctl reboot
Usefull note.
Remove all non relevant ifcfg* files from /etc/sysconfig/network-scripts as networkmanager will try to load extensions ( like .bak or .sav or .henk etc)
So if you want to backup an interface, save it in a different director
Re: EFA 4 beta
As sqlgrey has no permissions in /var/run, just create a sqlgrey dir with sufficient permissions for sqlgrey.
the mariadb.service dependency is also need on boot as mentioned earlier.
The Err message on stopping the service : efa4 sqlgrey: Couldn't unlink "/var/run/sqlgrey.pid" [Permission denied]
/etc/sqlgrey/sqlgrey.conf
## PID
# where to store the process PID
# pidfile = /var/run/sqlgrey.pid
pidfile = /var/run/sqlgrey/sqlgrey.pid
mkdir /var/run/sqlgrey
chown -R sqlgrey:sqlgrey /var/run/sqlgrey
Now change the pidfile location to the new location
[Unit]
[Service]
Type=forking
PIDFile=/var/run/sqlgrey/sqlgrey.pid
[Install]
systemctl restart sqlgrey
Re: EFA 4 beta
Dr. is in. Reviewing and preparing list of new issues to tackle :D
jamerson
Re: EFA 4 beta
Post by jamerson »
shawniverson wrote: 22 Jan 2019 23:22 Dr. is in. Reviewing and preparing list of new issues to tackle :D
Dr. we need the medicine :) :clap: :clap: :clap:
Re: EFA 4 beta
Repo updated with new fixes.
jamerson
Re: EFA 4 beta
Post by jamerson »
shawniverson wrote: 23 Jan 2019 04:43 Repo updated with new fixes.
The medcine works :)
ClamAV Version: 0.101.1
PHP Version: 7.2.14
however on the admin email we keep recieving this error
from (Cron Daemon) <root@efa.org>
/etc/cron.hourly/mailwatch_relay.sh:
/usr/bin/php -q /usr/bin/mailwatch/tools/Postfix_relay/mailwatch_postfix_relay.php
Re: EFA 4 beta
it's a miracle, the speed of changes. In one word: amazing :clap:
Reverted and applyed to yum update.
Preparing to update eFa...
checkmodule: loading policy configuration from /var/eFa/lib/selinux/eFa.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 19) to /var/eFa/lib/selinux/eFa.mod
Error updating eFa, Please visit https://efa-project.org to report the error.
warning: %post(eFa-1:4.0.0-7.eFa.el7.x86_64) scriptlet failed, exit status 1
Non-fatal POSTIN scriptlet failure in rpm package 1:eFa-4.0.0-7.eFa.el7.x86_64
Since it was non fatal I continued:
The important line: warning: /etc/clamd.d/scan.conf created as /etc/clamd.d/scan.conf.rpmnew
Mailscanner --debug --lint
Cannot find Socket (/var/run/clamd.scan/clamd.sock) Exiting! at /usr/share/MailScanner/perl/MailScanner/SweepViruses.pm line 2159.
shows new entries:
# Sets the group ownership on the unix socket.
# Default: disabled (the primary group of the user running clamd)
#LocalSocketGroup virusgroup
Just learned that x generates a red X
getent group
clamupdate:x:994:clamscan
virusgroup:x:993:clamupdate,clamscan
apache:x:48:
php-fpm:x:991:
clamscan:x:990:
postfix:x:89:
mtagroup:x:1000:clamscan,postfix,mail,apache,php-fpm
tempFix to proceed testing:
chown -R clamscan:mtagroup /var/run/clamd.scan
spamassassin --debug --lint
Jan 23 11:46:23.506 [1839] dbg: rules: ran body rule __BODY_TEXT_LINE ======> got hit: "I"
Jan 23 11:46:23.575 [1839] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
To avoid the looping test
meta __E_LIKE_LETTER (0)
meta __LOWER_E (0)
Now login thru the GUI
By changing the mpm_prefork_module to mpm_event_module in /etc/httpd/conf.modules.d/00-mpm.conf the mpm warnings are gone! :violin:
Also the strange behaviour of the Gui is solved :clap:
Not able to view MailScanner configuration In Mozilla. Logout with message: your session timed out
Mozilla private window works. Chrome also work fine
## Update: on a different pc Mozilla works fine, ( before you will ask me: yes the OS versions are the same and also the brouwer version match)
Will continue testing
jamerson
Re: EFA 4 beta
Post by jamerson »
I noticed the "  file.name.pdf" are blocked
Would love to get this fixed in the next medicine.
Thank you for the hard working.
vervoto1
Re: EFA 4 beta
Post by vervoto1 »
found a typo in the postfix master.cf
smtpd_sasl_security_options
-o smtpd_sasl_security_options=noanaonymous
is generating an error when a server from the LAN wants to connect..
change to noanonymous and it works like a charm.
Found another one in the first Init.. if the machine is running LXC under a vmware machine that does not have an RTC the init script fails as timedatectl returns an error.. if you comment out the 2 'timedatectl' lines below in /usr/sbin/eFa-commit it works.. bit of a dirty workaround though
if [[ $configtzone -eq 1 ]]; then
  virtplatform=`/usr/sbin/virt-what`
  [ $verbose -eq 1 ] && echo -e "$green[eFa]$clean - Configure timezone"
  if [[ "$virtplatform" != "lxc" ]]; then
    if [[ $ISUTC -eq true || $ISUTC -eq 1 ]]; then
#      timedatectl set-local-rtc 1
      [ $? -ne 0 ] && exit 1
    else
#      timedatectl set-local-rtc 0
    fi
  fi
Re: EFA 4 beta
Thanks for update, adding to the next round of fixes :D hopefully we'll have an RC2 ready here soon and can start adding back some features...
jamerson
Re: EFA 4 beta
Post by jamerson »
shawniverson wrote: 26 Jan 2019 20:17 Thanks for update, adding to the next round of fixes :D hopefully we'll have an RC2 ready here soon and can start adding back some features...
is this related to the outbound ?
