Increasing Partition Sizes
You may find after running E.F.A. for a while that you may need more capacity. Here's a how-to.
1) Shutdown MailScanner to halt mail processing
sudo service MailScanner stop
2) Recommend a full backup before proceeding. (Don't snapshot, you won't be able to resize the disk...) This procedure varies depending on what type of virtualization/backup solution you are using.
3) Shutdown your system.
sudo shutdown -h now
4) Increase the size of your virtual hard disk. In VMware...right click VM --> Edit Settings
disk resize
disk resize
Optionally, you can also add a new virtual hard disk to add capacity, in case your solution doesn't allow you to dynamically resize your virtual hard disk.
5) Start your EFA and have the console open. When the countdown appears, press a key to interrupt automatic boot
6) Press 'e' to edit the boot options, arrow down to the line starting with "kernel", press 'e' again, and add 'single' to the end of the line with a leading space
7) Press enter and 'b' to boot. This will take you to single user mode (init level 2)
8) On the commandline, launch fdisk
fdisk /dev/sda
Press p <enter> to view existing partitions.
(note that if you added a new disk, the next disk will be /dev/sdb instead)
9) Create a new partition
9a) Press n to create a new partition
9b) If you already have 3 partitions, choose extended 'e' <enter>, otherwise choose primary 'p' <enter>
9c) Accept the default first cylinder <enter> and last cylinder <enter>
9d) If you created an extended partition in step 9b, create a new partition again, accepting defaults for cylinders.
9e) Press 'p' to view partitions again, and note the name of the new Linux partition. Press 't' <enter> to change the partition type.
9f) Choose the appropriate partition, press <enter>, and enter '8e' for the type <enter>
9g) Check your work with 'p' <enter>. If satisfied, type 'w' <enter> to save your work.
10) Reboot the system, and return to single user mode using steps 5-7.
11) Add the new partition to the LVM pool
Run pvcreate (changing /dev/sda5 with the name of your newly created partition)
pvcreate /dev/sda5
pvdisplay
You should see a new PV. Now add the PV to the volume group, replacing /dev/sda5 with your partition.
vgextend vg_00 /dev/sda5
pvdisplay
12) Now it is time to resize the logical volume. I will demonstrate with /tmp (you can also increase /var or / this way). Because these volumes are mounted, we will perform a live resize.
lvdisplay
13) Making note of the LV Path, execute the following, substituting the device and size that you desire
lvextend -r /dev/vg_00/lv_tmp -L +10G
14) Reboot the system.
shutdown -r now
microcore
Re: Increasing Partition Sizes
Post by microcore »
Why the EFA dont has pvextend command?
Thank
I have pvextend command. Is it not present?
david
Post by david »
also in my installation, command pvextend is not present. I used vgextend and worked properly.
Widmo
Post by Widmo »
lvextend maybe?
david
Post by david »
dbator
Post by dbator »
I also did not have the pvextend command. vgextend worked perfectly.
Other than that, thank you for this tutorial! very, very helpful
Updated how-to to use vgextend :) :) :)
blobb
Post by blobb »
The instructions above are awesome... but I changed them a little...
I increased the storage in VMware
then booted to GParted Live.
The extended the var group by the amount I increased the partition.
This worked. Thanks from the instructions
DrDomino
Post by DrDomino »
worked perfectly
thank you
yahav02
Post by yahav02 »
hi
Is it possible to build OVF file with 100 GB VAR folder?
The 3.0.1.5 ovf is 100GB now.
webguyz
Post by webguyz »
The downloads section OVF files all have a version of 3.0.0.9. Where do you get a version 3.0.1.5 that has the larger partition?
Never mind! There is a link at the bottom of each message :-)
Thanks for this great utility!!
mavelit
Post by mavelit »
Great guide!,
i would remenber to use last command :
resize2fs /dev/vg_00/lv_tmp
or
resize2fs /dev/vg_00/lv_var
for complete the extension of fs.
bye!
bikertrash
Post by bikertrash »
Sorry to report... none of this worked... restoring the entire device from a backup copy...
Is there a thread thart's a little more up to date??
bikertrash wrote: 25 Dec 2018 14:55 Sorry to report... none of this worked... restoring the entire device from a backup copy...
What went wrong?
bikertrash
I kept bang'n on it until I figured it out (thanks to the URL listed above). I had problems trying to identify the partitions. :whistle:
I may still completely re-deploy in the near future though... as I'd really like to try and turn this guy into a full-on mail server so that I can ditch the outdated Exchange Server inside the network.
For the record... this server has been working flawlessly for several years now and pretty much NOTHING gets past it... :clap:
