Some dangerous files can pass trough (spaces in filenames)
endokard
Post by endokard » 28 Nov 2018 06:41
I’ve got a problem with archives. Recent I’ve got e-mail with virus inside rar archive. After some tests I found that MailScaner won’t scan archives wich contains spaces in name. For example, if I put notepad.exe in archive with name “notepad.rar” MailScanner blocks it, because archive contains executable file. But if I put the same notepad.exe in archive named “my favorite notepad.rar” MailScanner will pass it trough.
Do you have any idea how to fix it?
endokard
Re: Some dangerous files can pass trough (spaces in filenames)
Post by endokard » 03 Dec 2018 12:28
Problem solved with MailScanner update
Mail2GoCa
Post by Mail2GoCa » 15 Dec 2018 06:42
Can you post more details about how you updated MailScanner?
revlis
Post by revlis » 07 Jun 2019 08:49
not solved
viewtopic.php?f=13&t=3628
[root@mx1 etc]# EFA-Update -check
[EFA] Getting latest version number from http://dl.efa-project.org
[EFA] You are already running version EFA-3.0.2.6, no update needed
Post by shawniverson » 09 Jun 2019 07:05
Please plan on moving to v4. v4 is in RC3 and will be RTM soon.
Mail2GoCa
Post by Mail2GoCa » 09 Jun 2019 10:29
Is there a migration path yet?
Mail2GoCa
Post by Mail2GoCa » 13 Jun 2019 09:05
Thanks Shawn. :clap:
This is clearly a weekend job.
