How to use phishing.safe.sites.custom ?
ovizii
Post by ovizii » 22 Nov 2018 13:05
I had read (somewhere) that I can add safe sites in here to mitigate the problem that the global "bad" list lists onedrive.live.com and play.google.com by listing them inside phishing.safe.sites.custom - and yet even after restarting Mailscanner, these lists still get marked as phishing fraud.
Did anyone succeed and can explain how this works?
Re: How to use phishing.safe.sites.custom ?
Post by henk » 27 Nov 2018 11:51
As I have no answer, you could try Shortcircuit to bypass the blacklist, as onedrive.live.com is listed in phishing.bad.sites.conf
ifplugin Mail::SpamAssassin::Plugin::Shortcircuit
# default: strongly-whitelisted mails are *really* whitelisted now, if the
# shortcircuiting plugin is active, causing early exit to save CPU load.
# Uncomment to turn this on
shortcircuit USER_IN_WHITELIST on
shortcircuit USER_IN_DEF_WHITELIST on
# shortcircuit USER_IN_ALL_SPAM_TO on
# shortcircuit SUBJECT_IN_WHITELIST on
# the opposite; blacklisted mails can also save CPU
shortcircuit USER_IN_BLACKLIST on
shortcircuit USER_IN_BLACKLIST_TO on
# shortcircuit SUBJECT_IN_BLACKLIST on
# if you have taken the time to correctly specify your "trusted_networks",
# this is another good way to save CPU
# shortcircuit ALL_TRUSTED on
# and a well-trained bayes DB can save running rules, too
shortcircuit BAYES_99 spam
# shortcircuit BAYES_00 ham
whitelist_from info@onedrive.live.com
whitelist_from info@play.google.com
blacklist_from info@spammers.be
endif # Mail::SpamAssassin::Plugin::Shortcircuit
ovizii
Post by ovizii » 29 Nov 2018 20:41
Thanks for the workaround. I'll do that until someone finds a better way.
Post by henk » 16 Jan 2019 10:58
As I was looking for something completely different, I found this: https://www.real-world-systems.com/docs ... nConf.html
Whitelist and Blacklist options
unwhitelist_from uname@domain.com
Overrides a default whitelist_from entry, for example a distribution whitelist_from can be overridden in local.cf or for an individual user user_prefs.
The address has to match exactly the address previously used in a whitelist_from line. Examples:
unwhitelist_from joe@example.com fred@example.com
unwhitelist_from ∗example.com
unblacklist_from joe@ress.com
Used to override a default blacklist_from entry,
ovizii
Post by ovizii » 05 Mar 2019 11:54
Sounds good. here is a link to a more current documentation: https://spamassassin.apache.org/full/3. ... _Conf.html
I'm going ahead and will use:
unblacklist_from *@onedrive.live.com
unblacklist_from *@play.google.com
