How to do manual update?
dynamiclink
Install the hyper-v version of 3.0.0.1, can i do manual update before use it as product filter?
Re: How to do manual update?
Login with SSH
select option 1 to go to the shell
then run:
In a later version I will add the update option also to EFA-Configure
then run:
sudo /usr/local/sbin/EFA-Update -updateVersion eFa 5.x now available!
I know this post is kinda old.
Anywho, I just downloaded the VMWare virtual image and got it installed an configured. Since the download package was for 3.0.0.1, I thought this was the most current version. Reading through some of the posts, I came across one that stated 3.0.0.4 came out. Shouldn't the website get updated with the most current image? Also, is there a place in Webmin to check for updates to the currently running EFA version?
You can run EFA-Update to update to the latest version (or it will be automatically updated if you enabled auto update)
3.0.0.5 will have a new VM image also.
I don't want to turn on AutoUpdates, as this will cause the system to reboot if necessary, and I would like to control that rather than the system.
Do you think maybe in the next release, on the Webmin splash page, there would be a line there stating what version I am currently running?
