SSL on 3.0.2.5 - how to?
bostjanc
Post by bostjanc » 04 Nov 2018 19:47
Hi there.
I am trying to replace SSL certificate on EFA.
What I did:
into /etc/pki/tls/certs/localhost.crt i have overwritten my crt certificate from Comodo (its a wildcard)
and into /etc/pki/tls/certs/ca-bundle.crt i have overwritted CA crt from Comodo
rebooted server, but https://efa.domain.com does not open.
What am I doing wrong?
thewomble
Re: SSL on 3.0.2.5 - how to?
Post by thewomble » 06 Nov 2018 14:37
Is Apache running?
service httpd start
or service httpd restart
does that throw any errors?
bostjanc
Post by bostjanc » 08 Nov 2018 10:55
Thanks for the reply. Will need to check.
Is the approach even correct for changing cert on EFA or does it needs to be done on some other places/config files?
With best regards
B
thewomble
Post by thewomble » 09 Nov 2018 15:02
If you are using the same certificate for both TLS (mail) and HTTPS (web)
You have to make sure you have the appropiate lines in main.cf for the mail
and httpd.conf / or / ssl.conf for apache
I use a Digicert wildcard to do the same.
jkissane
Post by jkissane » 15 Jan 2019 16:10
Old topic I know but I just did this to get rid of the warning when users connect to the server to check spam etc. Where I work can generate our own certs so all I had to do was change three lines in the ssl.conf file:
SSLCertificateFile /etc/pki/tls/certs/efa_domainname_ie.crt
SSLCertificateKeyFile /etc/pki/tls/private/efa.domainname.ie.key
SSLCertificateChainFile /etc/pki/tls/certs/DigiCertCA.crt
Restarted apache & all was well.
bostjanc
Post by bostjanc » 15 Jan 2019 16:28
Thanks. Didnt have time to implement it yet but I will definetly use your tip. With best regards B
bostjanc
Post by bostjanc » 08 Jan 2020 12:35
Thanks, it helped
