I have a requirement to send all incoming emails via EFA to multiple backend mail servers.
There's only an option to specify one mail server under Transport settings.
I guess this might be a postfix limitation?
domain.com smtp:[192.168.1.1]
I could use DNS RR, but then half the mail goes to one server, and half to the other.
Any thoughts?
One EFA to multiple backend mail servers
Re: One EFA to multiple backend mail servers
Actually, I may have found a possible solution:
https://gitlab.dls-belgium.eu/tools/smptdd/tree/develop
Could this be implemented in EFA?
huh?
Just specify the domain and the back end in the transport file
etc...
You can do this through the efa configuration menu, or by hand.
mydomain1 smtp:[10.1.1.1]
mydomain2 smtp:[192.168.1.1]You can do this through the efa configuration menu, or by hand.
Gate Array
What do you need?
1) forward emails to ALL the mail servers behind (parallel approach)
2) forward email to one server with a rotational schema (es. round robin)
3) forward specific domain to a specific server
Was this ever resolved? I have a situation where we have efa feeding an exchange server and we also want all emails sent to a backup linux box so when the exchange server crashes we can still access our mail on the linux box. Is this possible?
I don't think so, you can only specify one destination in postfix.
If (or rather when) your Exchange server crashes, you would have to change the IP in postfix, unless you use a DNS entry, in which case change your DNS to point to your Linux box.
The "parallel approach" is something I've been trying to do myself.
