Cannot release messages from Spam Not Delivered Email
vanree-josh
Post by vanree-josh »
Came in this morning to find that our EFA box automatically updated itself overnight.
Since then, users are unable to release messages from quarantine, it looks like the release link is missing the token.
Any idea how we can fix this?
Regards,
Josh
cyberwired
Re: Cannot release messages from Spam Not Delivered Email
Post by cyberwired »
Can see same issue here as well
Email link comes through as http://efa.xxxxxxx.xxx.xx/cgi-bin/relea ... 9DE&token=
Page gives the following error: Error variable is empty at /var/www/cgi-bin/release-msg.cgi line 43.
If I add token=blahblah on the end, it says Error in token syntax at /var/www/cgi-bin/release-msg.cgi line 89.
darky83
Site Admin
Post by darky83 »
I see the same issue,
checking what is wrong
darky83
Site Admin
Post by darky83 »
:doh: :doh: :doh:
:violence-hammer: :violence-hammer:
Mistake in the update file :(
New updates should go fine now, if you have already updated I will push an new update as soon as possible.
Manually fix is below (login with ssh and su to root)
  EFASQLPWD=`grep EFASQLPWD /etc/EFA-Config | sed 's/^.*://'`
  sed -i "/^  my(\$db_pass) =/ c\  my(\$db_pass) = '$EFASQLPWD';" /usr/lib/MailScanner/MailScanner/CustomFunctions/CustomAction.pm
  /etc/init.d/MailScanner restart
buzzzo
Post by buzzzo »
Hi Darky.
Would be better to not hardcode pass in files and put them in an external file and let it call by the perl scripts ?
darky83
Site Admin
Post by darky83 »
That is the idea yea (and also the reason why all the passwords are set in EFA-Config)
This is an enhancement and on the todo list :-)
cyberwired
Thanks for the update darky, I've just done the manual mods you've mentioned, will report back if there's any further issues :)
tstell
Post by tstell »
i use the Version 3.0.0.8 and have a similar problem when user is pointing on the spam link:
Error variable is empty at /var/www/cgi-bin/release-msg.cgi line 53.
any idea for me???
What does your release url look like?
tstell
Post by tstell »
Here is an actual URL:
There is no token on that URL...is that the whole URL...i.e. the mail server/client didn't add a newline?
Also, what do you show in MailScanner.conf for the following settings...
Sign Clean Messages
Non Spam Actions
Spam Actions
High Spam Actions
tstell
Post by tstell »
i found the file mailscanner.conf at the location /etc/MailScanner and attached it
MailScanner.zip
(38.98 KiB) Downloaded 3429 times
Ok that config looks good.
Something is wrong in the custom action function on your machine...
Thinking about how to debug this...
Try replacing this file...
From here:
https://raw.githubusercontent.com/E-F-A ... mAction.pm
tstell
Post by tstell »
OK, is it neccesarry to restart any Service after replacing the file???
Yeah, restart MailScanner...
tstell
Post by tstell »
i get the same error on new spam Messages when i klick the link, do you have another idea?
nicutdk
Post by nicutdk »
the same problem for me
can you help us
Best Regards,
syed.saif
Post by syed.saif »
Can Anyone please help me out.
"http://domain.com/cgi-bin/release-msg.c ... 270&token=
Note that if this mail has been send to multiple recipients you will
release this mail to all users."
Token number is not showing here thats why i not able to release email from these links.
Waiting for the response
