Hi!
Is there a way to change or output or string, eset finds malware and page is borked, see attached image.
Long text in top virus
- efa_virus.PNG (38.8 KiB) Viewed 4333 times
Re: Long text in top virus
Wow, that's is really loooooooooooooooooooooong.
I would recommend opening an issue with MailWatch, looks like the Top Virus display needs to truncate the text prior to displaying it.
I've seen that under several circumstances where long text is in the headers or elsewhere. My bad, I've never bothered to report it before.
The solution should be a generic one.
If someone opens a bug report in mailwatch before me, could you post the link here? Otherwise, I'll do it the next time I notice a message with a long string on display.
There we go: https://github.com/mailwatch/MailWatch/issues/1110
Can I do something in the meantime?
Regards,
G
Regards,
G
