i am working with the efa since yesterday - playing around
What i realy need ist the following setup:
internet <=> email encryption gateway <=> EFA <=> exchange <=> email client
I played around with the Domain Relay, the Postfix Transport Settings and so on. I am able to configure the EFA so i takes Mails from Exchange Server and sent them to den encryption GW, but can´t configure it the same way it will recieve Mails from the Encryption GW.
An other try i played around with the above settings and changed ip adresses so it takes Mails from the Encryption GW, but cant´t sent them to Exchange
Bevore i get to detailed i just want to ask if someone already has a working config for this scenario? If necessary i can post detailed what i did and what was the failure, step by step.
Thank you in advance,
Chris
