mysql overloading system cpu/IO
BOOZy
Re: mysql overloading system cpu/IO
Post by BOOZy » 20 Sep 2018 10:17
Since about a week I'm seeing the same thing, MySQL I/O and CPU are really high.
My setup is running on VMWare ESXi as well, with 8GB of RAM. ESXi reports that slightly more than 2GB is actively used.
One thing I have noticed that it's not constant but with a certain interval.
I see 40 minutes of high load then 20 minutes of calm and then it repeats itself.
I suspect that 40 minutes length isn't fixed but correlated with CPU and I/O bottlenecks, but the one hour (40+20=60) cycle is interesting.
ls -la /etc/cron.hourly/ lists three tasks:
0anacron
mailscanner
mailwatch_relay.sh
Maybe one of those has something to do with it.
Post by pdwalker » 20 Sep 2018 10:33
When mysql is really busy, run this command and post the results here:
mysqladmin -uroot -p`grep ROOT /etc/EFA-Config | awk -F: '{print $2}'` processlist
Sure, mysql might be busy, but it'd be good to find out what it is doing at the time it is doing something.
Also, perhaps your mysql configuration is not optimal. We may need to see the contents of your mysql configuration files.
BOOZy
Post by BOOZy » 20 Sep 2018 10:48
error: 'Access denied for user 'root'@'localhost' (using password: YES)'
Now what? :(
Post by pdwalker » 20 Sep 2018 14:55
as root
# netstat -plutn
Post by pdwalker » 20 Sep 2018 14:58
One of those things listed will me the mysql process on port 3306 and the ip address
then you can run:
mysqladmin -uroot -h<ip address> -p`grep ROOT /etc/EFA-Config | awk -F: '{print $2}'` processlist
BOOZy
Post by BOOZy » 21 Sep 2018 12:17
Ok. It took some time to unpack the mysqladmin line and why it wouldn't work but I got it now.
Result:
| Id | User | Host | db | Command | Time | State | Info | Progress |
| 14 | sqlgrey | localhost | sqlgrey | Sleep | 87 | | | 0.000 |
| 11222 | mailwatch | localhost | mailscanner | Query | 0 | query end | REPLACE INTO mtalog (`timestamp`,`host`,`type`,`msg_id`,`relay`,`dsn`,`status`,`delay`) VALUES (FROM | 0.000 |
| 11272 | mailwatch | localhost | mailscanner | Sleep | 3 | | | 0.000 |
| 11339 | root | localhost | | Query | 0 | init | show processlist | 0.000 |
BOOZy
Post by BOOZy » 21 Sep 2018 14:48
And when I/O is low:
| 14 | sqlgrey | localhost | sqlgrey | Sleep | 117 | | | 0.000 |
| 12007 | mailwatch | localhost | mailscanner | Sleep | 3 | | | 0.000 |
| 12255 | root | localhost | | Query | 0 | init | show processlist | 0.000 |
So it looks like the mailwatch process is doing something strange:
REPLACE INTO mtalog (`timestamp`,`host`,`type`,`msg_id`,`relay`,`dsn`,`status`,`delay`) VALUES (FROM | ----- trunkated.
BOOZy
Post by BOOZy » 24 Sep 2018 07:30
And it went away... All by itself.
ladylinux
Post by ladylinux » 30 May 2019 14:42
Centos 7 EFA 4
I added this to mysql and load went from 100% to almost nothing.
skip-name-resolve
I can't imagine since this is only for EFA why anyone would do host name lookups with Mysql
LadyLinux
Post by henk » 31 May 2019 07:10
From the mysql documentation : https://dev.mysql.com/doc/refman/5.7/en/host-cache.html
You should check your EFA Unbound dns. As the dns seems to be a problem. Mysqltuner provides usefull info.
To bypass dns issues with mysql and bump up security by using localhost for connections only
1. /etc/my.cnf.d/server.cnf
bind-address = 127.0.0.1
skip-name-resolve
skip-host-cache
