SPF issue from internal senders
gregecslo
Post by gregecslo »
Hi!
My situation.
1 exchange 1 efa appliance.
SPF set and working great.
Issue:
When internal sender sends mail flow is: CLIENT --> EXCHNAGE (10.10.0.90) --> EFA (192.168.1.10) --> internet
EFA reports this:
DMARC-Filter: OpenDMARC Filter v1.3.2 efa.domain.local 564DA20870
Authentication-Results: efa.domain.local; dmarc=fail (p=none dis=none) header.from=mydomain.com
Authentication-Results: efa.domain.local; spf=fail smtp.mailfrom=user.name@mydomain.com
DKIM-Filter: OpenDKIM Filter v2.11.0 efa.domain.local 564DA20870
And scores:
-1.00 ALL_TRUSTED Passed through trusted hosts only via SMTP
-0.59 AWL Adjusted score from AWL reputation of From: address
-1.90 BAYES_00 Bayes spam probability is 0 to 1%
0.00 HTML_MESSAGE HTML included in message
0.20 ImageCerberusPLG2
4.00 SPF_FAIL SPF: sender does not match SPF record (fail)
Why is it doing SPF test from exchange to efa, when it`s clear that it`s internal?
Have I misconfigured something?
Re: SPF issue from internal senders
gregecslo
Post by gregecslo »
Huh...
I ended up editing opendmarc.conf and adding ignore.hosts.
That cleared DKIM/SPF issue completley.
Ah yes, it was opendmarc, :roll: :oops: not SA.
