Quarantine Reports
Archer
Quarantine Reports
Post by Archer »
Hello all, Newbie here.
I have read, searched, and etc. to find out about marking option to send daily Quarantine Reports as a default for all users. (Or at least all new users.)
Is there anyway to make this happen?
We are in the process of removing our old filer and moving to EFA. But our users are accustom to receiving daily emails. And they do not handle change well. :roll:
Re: Quarantine Reports
How are you adding users to EFA?
Archer
Post by Archer »
I have it bound to our AD servers, so if somme one logs in with ad creds it makes the account. I have thought about using the AD import tools to pull them all in at once. As of now I have not done either as I was trying to find this solution before making all accounts.
Yeah, by default, the Send Daily Report is not checked for users.
Of course, you can go in and change the users, but if you have a lot of users, this is time consuming and very inefficient.
There's a few ways to accomplish this currently.
1) You can edit the /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php as follows:
Original code
    $users_sql = "
SELECT
 username,
 quarantine_rcpt,
 type
FROM
 users
WHERE
 quarantine_report=1
Edit as follows
    $users_sql = "
SELECT
 username,
 quarantine_rcpt,
 type
FROM
 users
This will ignore the flag in MailWatch and send a quarantine report for all users. Note that updates to mailwatch will likely overwrite this change, so it will need to be changed again after an update.
2) Another way is to mass update the users table
Look in /etc/EFA-Config for the MAILWATCHSQLPWD
mysql -u mailwatch --password=<MAILWATCHSQLPWD>  -e 'UPDATE users SET quarantine_report=1' mailscanner
3) You can also set the quarantine_report to default to 1 in the database
mysql -u mailwatch --password=<MAILWATCHSQLPWD>  -e 'ALTER TABLE users ALTER COLUMN quarantine_report SET DEFAULT 1' mailscanner
Archer
Post by Archer »
Cool. I will put that into use in the AM.
Thanks!!!
Archer
Post by Archer »
:dance: That was just too cool.....you just made my day!!!! :dance:
james27_84
Post by james27_84 »
This was working great until the latest version of EFA. Now all non spam email is listed in the quarantine report with the reason listed as "UNKNOWN" but when I check the users mailbox they were delivered successfully. Is there a way to stop non-quarantined emails from appearing on the daily quarantine report?
Yes, check out the new settings in /var/www/html/mailscanner/conf.php.
james27_84
Hello All,
Just had to set up a new EFA appliance. Noticed that on the latest version these steps are no longer relevant. Can anyone tell me how to go about turning on quarantine reports for all users in the latest version.
The sql method should still be valid.
james27_84
Thanks shawniverson, you are correct. I tried it and tested today. Thank you for your help!
