I was wondering if anyone knows how to remove {Disarmed} for the incoming emails. Every time, I receive an cleaned email, I get a {Disarmed} in my subject line.
Thank you,
Bob
						how to remove {Disarmed} for incoming emails?
Re: how to remove {Disarmed} for incoming emails?
I found this one but not sure if this is a fix. Can someone verify it please?
sed -i '/^Disarmed Modify Subject / c\Disarmed Modify Subject = no' /etc/MailScanner/MailScanner.conf
well, this does not seem to work . I still get {Disarmed] in the subject line. Anyone has any ideas?
Thank you,
Thank you,
in /etc/MailScanner/MailScanner.conf, what is the setting of your "Disarmed Modify Subject" and "Disarmed Subject Text" options?
Please post the text in exactly as it appears in the configuration file. For example, mine is:
[root@efa log]# grep ^Disarmed /etc/MailScanner/MailScanner.conf
Disarmed Subject Text = {Disarmed}
